Error Code OE and Door will not unlock
I have an Asko W6511XXL and the washing machine is putting up error code OE and the door remains locked... i pulled out the drain hose and cleaned it but it wont remove the error code or unlock the door
  • younghyphy_2 Dec 16, 2008
    The Model Number is WL6511XXLPP
    President:
  • 373 Answers
Error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.try running the spin cycle alone till the water empties completely.If the problem still continues it means that the pump is clogged where you cant reach, since you've tested with the drain hose.
Posted on Dec 16, 2008
  • 113 Answers
This is typically a long drain error code. It means the pump is struggling. Your pump is clogged and needs to be cleaned. Cant seem to locate that model. If you can get the complete model # I can tell you how to clean the pump. Thanks
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
Whirlpool WFW9050XW00 has 3 error codes: F5E2, F9E1, F8E1. Can you help. It won't advaance past the wash cycle.
Whirlpool error code site: http://producthelp.whirlpool.com/Laundry/Washers/Washer_Product_Assistance/Error_codes_in_front_load_washers
Sep 23, 2017 | Whirlpool Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
LO error code
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Oct 31, 2012 | Maytag Washing Machines
My maytag neptune MAH8700AWW shows an error code OE and the door is locked, how do I fix it?
Opening a locked door , click for a visual demo: Door locked#
It is possible that the actuator to the lock has failed and so is not releasing or there is a error on the control panel.
Jul 05, 2012 | Maytag Washing Machines
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
Error code oe
That's not OE, that's DE = Drain Error. Open the access door at the lower left on front of the machine. Use the small hose to drain the remaining water out of the machine, then open the large knob which is attached to the filter. If there is nothing in the filter, you may have an object which made it past the filter and is blocking the pump impeller, or the impeller may have come off the pump motor shaft, which would require pump motor replacement.
Oct 15, 2008 | LG WM-1485FHD Front Load Washer
Washing Machines Logo
819 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
