Question about Kyocera Mita FS-3800N Printer
Solid bar in graph is not fully covered
I'm sorry previous message gone without my permission. Can I replace drum of kyocera fs 3800 n with a drum from more popular say HP drum?
Well the graphics, in solid bars it does not cover all surface. It alternates between bars from page to page. Plenty of toner. I suspect that old drum has lost it's properties to hold toner. So I may perhaps find reasonable drum from other printer more popular and easy to get.
Thanks
  • 41 Answers
Hi zmienny
Unfortunetly Kyocera and HP drums not ineter change able. You will have to get the Kyocera fs3800n drum to replace.
Regards
Go-Tech
Posted on Dec 16, 2008
Error code on kyocera fs-2000 printer 7410:0588526
the error Call Service 7410:xxxxxxx usualy is about the Drum Unit not fully inserted in the printer.
On the left side of the printer you will need to open the cover and push the Drum Unit in place.
After it clicks in place power off and on the printer.
Best regards.
Oct 26, 2016 | Kyocera Developer Unit - FS-2000 3900 4000...
Kyocera FS-3920DN call service 2000:0011742
The call service 2000 is about the main motor. Pull the Developer Unit and then the drum unit out of the printer and check if the gears on both units are moving freely. Then turn the printer on without the 2 units and see if the motor is functioning. If your the motor moving then the message displays on printer will be 7410 (because you have the drum unit outside). There is a possibility that the transfer roller is damaged.
Mar 26, 2014 | Kyocera Fs-3920dn Laser Printer
Machine showing machine failure call service
The waste box is integrated into the drum unit housing. DIRTY JOB without a toner vac. There are two ports (one one each side). The covers pry off. The service manual doesn't cover this because they want you to replace the drum.
Jan 05, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Black dots printing on left side of paper
dots are usually always caused by the drum..drums are very easy to replace..(you don't even need a screwdriver)
here's how..
remove the unit that the toner sits into..it's called a process unit..comes out as a whole with the toners...
next open left cover..
remove waste toner bottle. (drum sits right above it!!!
next remove drum by pushing on grey button and pulling drum
out the left side of the printer.
as far as the jam message you might need to replace tray feed tires located up under the machine
Jan 11, 2010 | Kyocera FS-3900DN Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Error code on kyocera fs-3800 printer
E1: xxxxxxxx = Main motor error
Either the motor aint turning or it is being stopped from turning...Usally drum or developer units cant turn, or main motor or control board stuffed...
below is stuff from service manual and ....my comments
Suggested causes
The main motor is overloaded. Overcurrent in the main motor circuitry due to an excessive torque....... Check Drum, developer unit, toner cartridge and process units ensuring free movement
• Connector insertion error........check developer plug is secure (left top near toner cart little plug)
• Defective gate array U204 on the engine
board (KP-864). .......replace board
• Defective harness between engine board and
engine relay board (KP-760). .........secure replace cable
• Defective harness between engine relay board
(KP-760) and main motor.
Nov 26, 2007 | Kyocera Mita FS 3800 Laser Printer
Kyocera Mita FS-3800N Printer Logo
85 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
