Question about Presto HeatDish Compact Heater
Taking off the white grill to clean the inside (wipe dust off)
Does anyone have the m and/or does the manual give you instruction how to take the white grill off?  I lost my manual.  I had other try to take off and have the same problem.  I can't believe customer is having this same problem.  I also saw this at Costco but the foot of the base looked dark gray, I wonder they upgrade to fix this problem.  Does anyone have the manual and can you please sran and e-mail to me and/or fax to me at 610 330-2265.  Thank you everyone for your support.
  • 4 Answers
Remove the batteries, on the back.
You may remove the kerosene left over, by using your filling pump and transferring it, to the approved container, you use when buying Kerosene.
First, remove the wire handle. Pull gently outwards with the wire handle horizontally.
Second, lift one side of surrounding grill, until the top and bottom sides come off. Do the same on the opposite side.
Third, remove the top cover, by pulling upward.
fourth, unscrew the two side screws, located on the lower part of the cylindrical shape, that was surrounded by the wire grill, that was just removed.
Fifth, Remove the front know, by pullung outward.
Sixth, remove the cover and note that the balancing weight will come off. Very easy to reinstall.
Seventh, Remove four nuts, on the outer space of the wick and cover assembly.
Eight, Remove the wick by pulling downwards and nothing that there are two pins. When reassembling with new wicker, assure that the pins in the new wicker fit the hole openings, properly.
Installing follow the reverse of the above noted points. The whole work should not take more than 20 minutes.
Tools required are: flat screw driver, need nose pliers.
Be a little patient.
Call me at 610.217.8133 . Please note that I have the same model and have changed wicks, as per instructed by mfgr.. If you want a manual, I will send a copy. prepaid by all mayor credit cards, in the amount of $10.00.
Good luck.
Posted on Dec 16, 2008
Need instruction manual for GR15 George Foreman indoor grill
Hi there.
You may be able to find owner's manual at http://www.georgeforemancooking.com
Regards.
Jun 04, 2012 | George Foreman GR15 Indoor Grill
I've lost my instruction manual. Where can I get another one?
Easy! From this pdf page:
http://docs.barbecues.com/PE-Links/Brinkmann/Brinkmann-815-3060-4-manual.pdf
It is the real instruction manual!
Jul 02, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
I have lost my instruction manual for the George Forman Party time Grill
to it may concern, i have lost my manual for georgeforman rotiserie, the model # gr82, can you help?
my email. slystone@triad.rr.com
Dec 31, 2009 | George Foreman GR10AWHT Indoor Grill
Instructions for a Brinkmann Smoke 'n Grill
how do I use my brinkmann smoke n grill? lost my instructions
May 26, 2008 | Brinkmann Smoke 'n Grill 810-5304-E
Instructions for use
Here's the link; http://www.esalton.com/static/manuals/GR20WHT.pdf Hope this helps :)
May 17, 2007 | George Foreman GR20CB XL Indoor Grill
Presto HeatDish Compact Heater Logo
116 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
