Question about HP Pavilion ZE5200, ZE5200 CTO, ZE5207, ZE5217, ZE5228, ZE5232, ZE5236, ZE5238, ZE5240, ZE5242, ZE52... (810247012045) Floppy Drive
My hp pavilian will not power up
I turn it on, it hits the hp logo, then shuts off.
please help me!
  • Anonymous Feb 05, 2009
    HP 520C desktop does not power up at all. Checked transformer and that gets power and LED comes on but front power switch does not turn computer on.
CHECK UR HARD DISK.IT MAYBE AN ERROR ON UR HARD DRIVE..CHANGE IT AND REFORMAT.......TY
Posted on Sep 24, 2012
    Problem Solver:
For zackmark96, your machine most likely is infected with viruses. You will need to format the machine and reinstall Windows. If you have files that need rescued, you can boot from a rescue CD. I recommend Hiren's Boot CD.
For Guest whose computer does not come on at all, I would guess that your problem is the power supply. You can try a different cord and a different outlet first to make sure those things aren't causing a problem. To verify that the power supply has a problem, it is easiest to take it and let someone check it for you. Places like Staples will do it for free I believe.
Posted on May 30, 2009
I have a hp pavilian slimline desktop that sat unplugged for over a year and now I have a need to use it but when I try to turn it on all that happens is the eternal fans come on for a second and then turn...
IT MIGHT BE SOMETHING THAT IS PLUG IN THAT IS CAUSING IT TO SHUT DOWN. UNPLUG EVERYTHING EXECPT VIDEO AND POWER. TRY AGAIN. THEN WITH IT OFF TRY JUST KEYBOARD, REPEAT, UNTIL YOU FIND THE PROBLEM. GOOD LUCK.
Oct 25, 2014 | Computers & Internet
Dell power supply turns off by itself until I unplug it and replug it in. how do I get it to stay on? power supply is new from local pc repair shop,
Probably best to return to the shop with the pc and power supply. Possibly a loose connection somewhere or the power supply could be overheating.
Mar 27, 2012 | HP Computers & Internet
How to boot my pavilian n3250 without any disk
If you have a recovery partition on the hard drive, press power when logo appears you sould see F2 and F10, press F10 while logo is visable this should put you in the recovery sector, follow the prompt for a complete install. If it turns out the option is not available, you will need the recovery disc.
Mar 14, 2012 | HP Pavilion N3250 (F1916A) PC Notebook
I have an hp pavilian atx-250-12z and the tower itself will turn on and the mouse to will turn on but the monitor gets no signal and the keyboard will not turn as well..I have unplugged the cpu while...
Whom ever told you too: "Unplug the cpu while holding down the power button".
Is telling you something that can "seriously damage" your cpu and computer.
Or did you mean "PSU" if so there is a particular format to do a Power supply check.
For the proper way use this link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&product=405227&dlc=en&lang=en#N207
Also many other things can cause the problems your having. Could be your motherboard too.
If this does not work, post again be sure to include HP Pavillion Model number and Operating System (i.e. XP, 7 or Vista) that way we can help pin point your system needs. Also have you done any internal repairs lately? Recheck all your connections too.
If you find this helpful please vote.
Oct 07, 2010 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Problems with HP HP Pavilion dv5-1159se 15.4
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Pavilion dv5-1159se Laptop
How to change the Bios Boot on a HP Pavilian a141On
Go into the system BIOS when the desktop boots (usually by pressing del or F10) Go to the boot options tab and follow the instructions to adjust the order of the disks. F10 to save and exit - it should now boot to the required disk
May 07, 2009 | HP Computers & Internet
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Recovery of 2601 hp pavilian
You cant. Unless you create them yourself. HP will only allow back up disks to be created once. HP sucks. Sorry. You may try Best Buy's Geeksquad..they may have ones that they have backed up.
Dec 14, 2008 | Computers & Internet
I have a hp pavilian dv9013d entertainment notebook pc sn cnf6444fpx purched dec2006 I tryed to turn the power on it came on for 15 secounds then went blank it will no longer turn on I was useing the...
How did you test to see if your wall plug had power? Did you at least see the HP logo when you booted up your computer? let me know before I can give you further instructions!
May 08, 2008 | Computers & Internet
HP Pavilion ZE5200, ZE5200 CTO, ZE5207, ZE5217, ZE5228, ZE5232, ZE5236, ZE5238, ZE5240, ZE5242, ZE52... (810247012045) Floppy Drive Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
