Question about Hitachi 60SDX88B 60" Rear Projection Television
Water marks. I had a plant on top of the television - when i watered it some water ran over and went behind the screen leaving water marks on the inside. the tv still works fine but the lines are annoying. can the screen be removed and the inside be cleaned? If so, How and/or should i call a professional. What do you think this would cost?
Yes take the pannel off the back. be carefull your mirrors are in the pannel
Posted on Jan 09, 2008
What can be done for beans or peas with stunted growth
Plants stunted; vines off-colour; roots rotten or absent. Root rot and crown rot. Improve soil drainage by adding aged compost to planting bed. Destroy infected plants. Rotate crops. Plant resistant varieties.
Leaves curl under and become deformed and yellowish. Aphids are tiny, oval, and yellowish to greenish pear-shaped insects that colonize on the undersides of leaves. They leave behind sticky honeydew. Spray away aphids with a blast of water. Use insecticidal soap.
Leaves turn pale green, yellow, or brown; dusty silver webs on undersides of leaves and between vines. Spider mites suck plant juices causing stippling. Spray with water or use insecticidal soap. Ladybugs and lacewings eat mites.
May 02, 2017 | Garden
When tomato plants put on green tomatoes. yellow leaves form at bottom with black spot inside. Usually killing plant. can you help?
Might be Tomato Mosaic. Plant should be destroyed as it can spread to other plants. Tobacco on hands can start it off strangely enough. Or could be too much watering at one go, moderate watering about twice a week in dry hot weather, and a little shade while the leaves are still tender. Feed often, but not too strong.
Apr 11, 2017 | Garden
How to care for ho useplant begonia rex?
Growing Requirements for Rex Begonia Plants Rex Begonias grow best in bright, indirect sunlight coming from an east or west window.
Fluorescent grow lights are also an excellent alternative to natural light for these plants,
and in many cases will intensify the foliage colors.
When potting, set the plant with the crown slightly above the soil line.
They should be planted in a porous, slightly acidic planting mix that contains some peat moss
and leaf mold. African Violet potting mixes work well for Rex Begonias.
Allow the top 1inch of soil to dry before watering, then water thoroughly.
Over watering can lead to root or crown rot! Wet foliage can cause problems with mildew.
Always use room temperature water when watering house plants.
House plants should never be allowed to stand in water for more than a few hours.
Painted-Leaf Begonia plants thrive with daytime temperatures of 70-75
and 60-65 at night. NEVER lower than 60!
They require a humidity level of at least 50 percent and appreciate periodic, light misting.
Provide additional humidity by setting the plants on shallow trays filled with moistened pebbles,
or a humidifier, especially during the winter months.
Feed actively growing plants in early spring and again in early summer with a slow-release plant food,
or every 2 weeks using a quarter strength dilution of a soluble, complete fertilizer (23-19-14).
Decrease feeding in early fall and stop altogether in the winter. Do not over-fertilize!
Your Begonia Rex may go dormant in the winter and possibly drop its leaves.
If this happens, continue to water sparingly until spring when new leaves will re-appear.
If your Rex is growing where it only gets light from one side ( a window sill),
turn the pot a quarter turn each week to maintain even growth.
Foliage color may fade under low light conditions. Consider using a grow light.
Remove any dead leaves and other debris around plant regularly.
Rex Begonias enjoy spending the summer in a shaded part of the garden.
Always be sure to check for insects and pests before bringing your plants back indoors!
Rex Begonias are susceptible to attacks from mealy bugs.
Aug 03, 2014 | Cycling
Rubber tree plant
This can happen for a few reasons, all involving water in one form or another. A rubber tree that is underwatered or overwatered will curl its leaves. As will a rubber tree that is in too low of a humidity or in poor soil.
When watering water when the soil is dry to the touch about 1 inch down and then water with enough water to that water runs out the holes each time. This helps remove any build up of soluable salts. IF the tree has recently been moved and lost leaves, the tree should put out new leaves but they will not be in the quantity that they were when the plant was brought in. Fertilizer should not be used at this time of adjustment. Only after the plant gets settled into the new location and then about once a month or so.
Information About Rubber Trees
Feb 01, 2014 | Garden
Information about clematis plant.
Clematis is a wonderful flowering vine that is known to many
in the gardening world as the "Queen of the Climbers".
While clematis takes a few years to establish a strong root
base before it hits it\'s stride in the blooming department, it is definitely worth
the wait.
This plant climbs up to 12 feet high and spreads 3 to 4 feet
wide.
If planting more than one follow the steps below spacing the
plants 3 to 4 feet apart.
In the spring or early summer, dig a hole one foot deep and one foot wide.
Mix the soil from the hole with compost, working it until it maintains a loose
rich texture.
Ideally this should leave you with a very dark soil.
Create a mound in the bottom of the hole using the
enriched soil.
Place the plant above the mound and allow the roots to trail
over the mound.
Cover the roots and fill in the hole with the enriched
soil, keeping the crown of the plant about 2 inches below the soil level.
This plant likes shade on the bottom and sun on the top.
Water at planting and regularly for the first season,( I
prefer to water in the morning or evening and do so every other day.) after
that you should only need to water in extreme dryness and drought.
Install a piece of trellis or fencing behind the Clematis
to give it support as it grows and a foothold for climbing.
To promote blooming and keep your Clematis healthy, prune
as needed after the blooming season, and in preparation for the blooming season
prune in late March each year.
Aug 08, 2013 | Computers & Internet
Ficus trees loosing leaves turnig yellow and falling off
How long have you had the tree?
Indoors or out?
If indoors, do you have any new plants in the house?
Have you moved the plant recently?
Your problem could be any one of:
  1. An infestation of tiny insects. Spray a solution of soap and water all over the plant, top and underside of leaves, until it is dripping. This will kill the insects.
  2. Overwatering. Hard to fix. Try transferring to a bigger pot and mixing in new dry soil. Or poke holes in the soil around the roots with the handle of a wooden spoon to let the air in.
  3. Underwatering. Put the plant in the bath, turn on the shower, set to tepid (i.e. not freezing cold and definitely not hot) and give it a good soaking. But take the pot out of the tray or dish and let it drain. It should not be in standing water. Don't water "little and often" - this is bad... give it a good soaking and then let it dry out.
  4. Chemical build up from tap water. If you see a salty-looking depsoit aorund the pot, or brown depsoits. do the same procedure as above.
Hope this helps.
Sep 01, 2009 | ArcMedia Home Gardening (SBX886) for Mac,...
Water down the front of the screen and the tv turned off and it won't turn back on. Will it dry out and turn on later?
its not good remember water and power does not mix most likely shorted some parts if you do take this set to tv shop make sure you move the plant to a diffrent location okay when the tv is on it has all diffrent voltage okay when you add water to a printed circuit board its not good take to tv shop see what they say i prbally would not waste the the money on a repair when you can buy a tv w/ a warrany okay have a good day
May 12, 2009 | RCA 32F531T 32" TV
Moisture behind screen
It is difficult to clean/remove the screens. Best case senario, it will dry up leaving little to no water mark. There are three screens, liquid gets between them and it sucks it in. Disassembly and cleaning will fix, but the screens are very fragile and cannot be wiped without potential damage. Any dust, dirt between them will show in the picture. Proceed at your own risk.
Sep 04, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hitachi 60SDX88B 60" Rear Projection Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
