Question about Harman Kardon CDR30 2-Disc CD Recorder
I can't open the tray on the recorder side.
Cdr26
I had similar problem with both drawers. The belt from the drive motor to the drawer pulley is worn. mcmelectronics.com has two belts 42-1050, 42-045 that are close enough in size to work. Remove cover, press down on tray, slide tray forward about half way and you will see the worn belt. Total cost of fix is about $12.
Posted on Apr 25, 2009
The disk tray on the recording side of the recorder will not open.
use a paper clip to open. first strighten out the paper clip. make sure power is off to the unit. then with the paper clip insert into hole on the player. the tray will eject out. good luck.
Oct 24, 2014 | Audio Players & Recorders
Harman Kardon CDR30 2-Disc CD Recorder both cd
Open the unit, inspect any obstruction, look for the belt that driving the CD tray, if it is loose replace it.
Jun 12, 2010 | Audio Players & Recorders
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
Describe your Harman Kardon CDR30 2-Disc CD Recorder Problem It's a CDR26 and neither of the drawers will open.
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Feb 11, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Harmon Kardon CDR26 unit shuts off
This is a problem in the power supply, various components go dry jointed.
Regards.
http://www.audiovisualservices.info/
Dec 11, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Dvd tray won't open
Don't take the cover off. Open the door and use a small flat instrument to depress the tray release buttom (it is indented on the lower right hand side of the tray. If there is a disk remove it. Turn off your system and the tray will close. Restart you system and see will the trat open.
Jul 15, 2008 | Lite On LVC-9016G DVD Recorder/VCR
Help with Harman Kardon cdr26
so u wann record u have to be in record mode 1st for signal to come throw and sorce vol up
Jan 27, 2008 | Harman Kardon CDR30 2-Disc CD Recorder
TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
Harman Kardon CDR30 2-Disc CD Recorder Logo
346 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
