Question about Casio SA-75 Keyboard
Casio CTK-541 Keyboard AC Housing
The AC prong is bent and needs to be soldered to the motherboard but the housing is broken. Where can I purchase a new ac prong and/or housing?
    Problem Solver:
  • 10 Answers
Many people have damaged ac power prong problems. Tools required is a soldering iron and solder wick or a bulb desoldering device . Next you will need Jamesco part no. 101178. This part matches the motherboard part in size and function.
How to : After removing all case screws open case from back. There you should see motherboard. You should desolder the power housing before you remove motherboard screws. (It is easier). After desoldering the power housing remove motherboard screws and gently loosen mother board. You should be able to remove power housing from board (caution if it sticks try remong more solder). Put in new part secure in place and solder (I use tape to hold in place) . AS a note once the motherboard is secured close key board and check for funtionality before puttting all those in place
Posted on Jul 09, 2009
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Wher can I get an instruction manual for my Casio CTK-551 Keyboard? And have it mailed in the mail
Click on the link below. It will bring you to a direct download page, which will then download the manual for the CTK-551 Keyboard.
Link: http://mypdfmanuals.com/user-manual/CASIO/CTK-551/270955.pdf
Aug 09, 2014 | Casio Keyboard CTK-551 power supply ac...
AC input pin broken
If it is part of the plug side that goes into the wall then it is not worth fixing. You can replace this pretty easy. On the front or back it will tell you what the input and output voltage are as well as the amperage. It will be 120v input and most likely a 12v output. Could be less like a 9 or 6 but that is the number you need to match. You will also need to match the amperage as well. It will most likely be in the milliamps. There are many universal adaptors that would work for you available at Walmart, Target, Best Buy etc....
Apr 13, 2014 | Casio CTK-541 Keyboard power supply ac...
Keyboard wont play with ac adaptor
Hi, Assuming you have tested with another adaptor then invariably it is a broken solder joint on the power input connector.
Re soldering will work but eventually the same thing occurs.
Set the connector in epoxy resin (Araldite) or better still mount a new connector in the case and wire with flying leads.
All the best, Chris the Fader.
Apr 04, 2014 | Casio Ctk 496 Electronic Keyboard with 61...
Ctk-651 sustain pedal working backwards
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
Dec 31, 2013 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
Keyboard not powering up. Want to change the fuse/s. Don't know where fuse is located.
There probably is NOT a fuse and usual cause is problem with the adapter or the power connectors. Broken solder of the connector in the keyboard is common. Broken cords on the adapter is common as well.
Oct 29, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
My Grandson's old Casio CTK-120 Keyboard is totally inoperative regardless whether batteries or the 9v adapter are used, I have used another 9v adapter, known to be good, as a further check. Are there...
If you have checked using anew adapter/battery and the CASIO CTK still does not work then its the motherboard inside that needs a repair.
Please take your Casio to a repairmen who should be able to check the current using a voltemeter and solder it at the right place.
The reason I am so sure that its the motherboard because your CASIO is not working directly with the adapter nor with the battery.
Would suggest you to take it to a experienced technician for soldering.
May 21, 2010 | Toys
No power is coming through to my CTK 611, bought a new power unit and this has made no difference
There is a chance that the jack that the power supply plugs into is broken loose or has bad solder joints to the circuit board. I am hoping that you purchased a direct replacement for the power supply.
Oct 29, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio PC Board Assembly
I do not know what part is # 69270460, it does not come in my part list. if it is the power supply socket on your keyboard, then it should be quite an easy task, providing that you have experience in soldering electronics. Todo the job you will probably need Casio schematics and service manual for 555L.
This website ask to do a donation to charity and will send the schematics. Give them (or ask the ladies) proof of recent donation to charity.
Alternatively this website sells schematics and service manual for a price between $10 and $20.
Regards
Mar 29, 2008 | Computers & Internet
Casio SA-75 Keyboard Logo
406 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
