Question about Vicks Warm Mist V745A 1 Gallon Humidifier
How do I clean my humidifier?
How do I clean it? it keeps shutting off
  • Anonymous Jan 20, 2009
    it shuts off when tank is still full.
  • Noah James
    Noah James Jan 26, 2012
    I have the same problem. Mine keeps shutting off and we just got it this week. The first day it worked but now it will run for a couple minutes and go to RESET with the tank half filled. Even in the beginning it wouldn't drain the whole tank. I don't think cleaning is an issue like stallion8 said. Mine is new and I've cleaned it three times already.
I had the same problem. This will cause the orange reset light to turn on as well. You need to remove the reservoir and the cooling chanber. Under the reservoir there is a locking mechanism that you push to the side. You then pull off the cooling tower. Then you push the locking mechanism in the other direction and remove the steam mechanism. I found a month of build up of "gook" inside. Dump it out and use a scrouring pad to remove it. After this was done, I could smell the vapor from the medicine cup again and it ran all night on the high setting again.
Posted on Jan 23, 2009
Drop one of these in the tank and it will inhibit bacterial growth and buildup.
http://www.kaz.com/kaz/store/product/02c128acb4e8bce666460152a5b832bf/
Posted on Dec 17, 2008
My humidifier keeps shutting off. Suggestions?
It may have to just be cleaned. Depending on what kind of water you put into it the filtration can get clogged up with minerals in the water. Try using distilled water. We have had our humidifier for months now and I have never had an issue.
Apr 10, 2017 | Humidifiers
Why does my Honeywell HMW450 humidifier keep shutting off?
Here are a few things to check:
-make sure the heating element is clean. If there is a thick layer of scale (mineral deposit), then the unit will not turn on.
-there are magnets on the water reservoir that allow the unit to turn on. If these magnets are not lined up properly, then the unit thinks there is no tank, and thus, not turn on.
-turn the humidity up past your target point. The humidity near the unit could be a lot higher than the rest of the room, causing it to shut off prematurely.
Hope this helps!
Apr 29, 2012 | Honeywell HWM-450 4 Gallon Humidifier
Does the Sunbeam Ultrasonic Humidifier Model 696-12 have a filter?
This humidifier is AMAZING. I’m a huge fan of using essential oils (lavender, lemongrass, spruce, rose, sandalwood etc) and I picked this up from a thrift shop, added some essential oils to the water and my house smells wonderful.
Essential oil diffusers are virtually the same thing design wise except cost a fortune. This is my best diffuser! I paid $10 for it and it works so good, throws off a ton of mist which I love (it’s so dry here) and I will enjoy owning this unit for years to come. Only thing is to gently clean the little ionizer part with the brush gently and keep it clean. Also..this unit unlike newer ones does NOT shut off automatically so keep an eye on it. Running it dry might cause it to burn out.
Jan 07, 2012 | Sunbeam Ultrasonic 81696 Humidifier
I have a honeywell he220a humidifier . the water drips in but does not get the filter pad wet.
Open the waterline tap valve or may have to clean small orifice that is in line where 1/4" line meets humidifier. Need to shut water off and in screw nut holding copoet line to humidifier
Jan 22, 2011 | Honeywell HE265 Humidifier
Mold is developing in drainage tubing - how do I prevent?
Keeping the humidity level in your home below 50% will greatly decrease mold growth. You can pour some bleach in the drainage tubing to clean it out and do it every three months to keep it clean
http://www.ehow.com/how_4798220_clean-honeywell-humidifier.html
http://www.forwardthinking.honeywell.com/related_links/humidification/truesteam/sell/50_9718.pdf
Feb 28, 2010 | Honeywell HE260A1010 Whole House...
Water running after heater shut off in humidifier
Hi check power at transformer / valve on water line could be stuck open clean valve out or transformer holding valve open
Dec 31, 2009 | Aprilaire 558 Humidifier
Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Feb 01, 2009 | Honeywell HE360A1027 Whole House...
Lots of water run-off from Aprilaire 760 Humidifier
HI would check the filter in side might need changing or cleaning clean out wter tray in side, it could be just a blocked filter , hope this helps
Jan 03, 2008 | Aprilaire 700 Humidifier
Vicks Warm Mist V745A 1 Gallon Humidifier Logo
1,211 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
