Question about GoVideo HT2030 System
No sound no video
I was hooking my system up to my computer which i bought a new sound card for and now i have no video and no sound i was getting alot of feedback and static and after that the dvd will play but theres no picture and he vcr will play but no sound
  • 3 Answers
SOURCE: how do i get the sound from the 360 to come out the GoVideo syste
have you red &white plugs go in to your reciever
Posted on Dec 02, 2008
0 characters
1 Points
Mtx surround sound sub is on but no sound or thump.
most electronics now days only last for about five to seven years
so I would get checked out by a technician.
Jan 27, 2014 | MTX Home Theater Systems
Trying to hook surround sound up to W/Westinghouse tv VR-3215
It depends on the connections you have on your TV and what other components you want to connect. So, they could both be right. You would probably get better results in the audio or TV sections. This one is for computer graphic cards.
Feb 17, 2013 | Panasonic SC-BTT195 Full HD 3D Blu-ray...
How to hook old surround sound sound up to new lg
if your old surround has either optical or coaxial connections you should be fine. if not you'll have to go with the audio in jacks (video 1,2 etc.) you'll get sound but not true 5.1 sound
Oct 22, 2009 | Home Theater Systems
We have a samsung hdtv monitor. Bought bose
you can try checking in your t.v.s menu for audio program
Sep 19, 2009 | Samsung Home Theater Systems
Can I hook my pc to my sound system
Your cable must be a minijack to 2RCA. Minijack connected at line out on computer and 2RCA at AV1 in or other available port in on HHTS(Home theatre) (white and red socket). That is sound only. Video will be yellow (or vga/DVI/HDMI depending on graphic card)from your graphic card to AV1 in. same port as sound. Now select AV1 on HTS. If no picture on tv make sure you computer graphic card is set for dual display .
Aug 29, 2009 | Panasonic Home Theater System System
No video signal from dvd player to tv.
Double check the way you've got the cables connected.  Audio but no video generally means that the yellow video cable isn't hooked up correctly.
Check to make sure the video cable (yellow) is hooked up to the same input on your television that your audio (red and white) cables are.
Mar 19, 2009 | Sharper Image GI300 System
Jolting sound in NEW computer
try to find a good tech guy, its just easy fif you find somebody to fixed. From now just use it with your usb, from now on tll you can find somebody to fixed your new staff.........
Jul 26, 2008 | M-Audio Audiophile 2496 PCI Digital Audio...
Hook up
well u cannot hook almost any devices with the SC-HT500.
I have this homecinema system for 5 years now, and i had to buy another stand alone DivX player to hook it up, but can't get the sound in dolby from the standalone player since the panasonic SC-HT500 has only 2 analog stereo RCA ports (audio in) in the back and a scart (A/V out) and component video (Video out).
At that time it was a very good system, but since i have bought a Full HD LCD tv with 1080p capabilities, I realised that my home cinema system i.e the Panasonic SC-HT500 is kind of useless, in the sense that you cannot even change the player for another one since the whole spaker and power connections are made trhough a special cable from the subwoofer. :(
best solution is that put the system back in a corner and get a new system which is not an all-in-one system. Preferrable get home cinema systems that come with a receiver, separate dvd player and speakers and subwoofer hooked to the receiver.
you asked how to hook these devices to your tv,, well the panasonic dvd recorder is better if you connect it via HDMI cable if you can. In the other case, connecting them with a scart cable would be another solution.
Dec 02, 2007 | Panasonic SC-HT500 System
Thm505 no sound
Nov 06, 2007 | JVC TH-M505 System
GoVideo HT2030 System Logo
19 people viewed this question
Top GoVideo Home Theater Systems Experts
Gyula Lacz
Are you a GoVideo Home Theater System Expert? Answer questions, earn points and help others
