Question about Toshiba Satellite M45-S331 Notebook
Hal.dll my toshiba m45-331 when i turne it on a blue screen comes on saying this HAL.DLL requires an mps version1.1system replace HAL.DLL with correct hal for this system the system is halting can somebody tell me how to fix this
  • Toshiba Master
  • 4,338 Answers
Here is a kink that will give you steps to tak to correct this HAL.DLL issue:
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 16, 2008
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 29, 2010 | Computers & Internet
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Systemroot/32 /hal.dll missing
You can download hal.dll here http://www.dll-files.com/dllindex/dll-files.shtml?hal (but are you sure it's missing and not just "hidden"?)
Nov 15, 2009 | Computers & Internet
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Even with correct pass phrase it still does not connect
Okay, the driver for WiFi (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32\
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the WiFi application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the WiFi driver, and the problem will be fixed!
Mar 12, 2009 | Dell Inspiron 1501 Notebook
Fairly old toshiba laptop with hal.dll error wont even boot now..
Well it must be an error when you install the windows XP...If you choose just to upgrade the your system then it might have an error on dll. Please reprogram your system i mean reformat your system. And not just upgrading well if ever you have an important data in the system then you must have a externat storage device then take it on your laptop.
Mar 08, 2009 | Toshiba Computers & Internet
Hal.dll error after booting
HAL - Hardware Abstraction Layer (hal.dll)
HAL is Microsoft’s abbreviation for the Hardware Abstraction Layer, the technology and drivers that let the Windows NT, 2000, and XP operating systems communicate with your PC’s hardware. HAL is one of several features–along with the NT file system (NTFS) that replaced the much less secure MS-DOS–that make NT-based operating systems more secure and reliable than Windows 95, 98, and Me.
HAL.dll prevents applications from directly accessing your PC’s system memory, CPU, or hardware devices (such as video and sound cards)–a method that can prevent many device conflicts and crashes. Unfortunately, HAL.dll sometimes also slows or stops DOS games and programs, which need to load their own memory managers or control hardware directly for better performance.
With HAL.dll in the way, developers must rewrite or even abandon their older software in favor of newer, HAL-compatible versions. Microsoft has pressured hardware makers to provide or support technologies such as MMX, DirectX, and 3D graphics language OpenGL, all of which allow fast but indirect access to the advanced high-performance features of video, sound, and CPU hardware. Such access also makes for a better visual experience when using Windows for Web and productivity applications; improved graphics performance is evident all over Windows XP’s new user interface.
XP also offers some new compatibility-mode features that let you run programs meant to run under earlier operating systems, but, frankly, most DOS-based and even some Windows-based games simply won’t work with the new OS.
Oct 05, 2008 | Computers & Internet
Toshiba Satellite M45-S331 Notebook Logo
201 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
