Question about Cozy (W352E) Heater
Heater egnites and shuts off
Heater fires up but when fan starts blowing fire shuts down
    Guru:
  • 462 Answers
Look at the flame when the blower starts. Does it change?
If so there may be a hole or crack in the heat exchanger and it may need a replacement or a new heater.
Particularly look at the area and flame associated with the pilot. If this becomes more erratic or lays down more it can be from a draft caused by the blower you may need to block the air and deflect it. Or blow out the pilot burner with compressed air and retry it this usually works especially if it has a lazy pilot flame.
If this helps you please let me know and rate me as high as you can. If not please restate your problem and tell me what you have tried. I will post back asap. Thank you and good luck.
Posted on Mar 23, 2009
My Dayton heater will not fire up and tries to fire and then shuts down tries to fire and shuts down blows smoke out the end
Check noggle for dirt, check fuel filter for dirt. Check al rubber hoses for leaks, Set air pressure All these will cause it not fire.
Dec 28, 2014 | Dayton Heating & Cooling
MY HEATER STAR RUNNING AND AFTER A MINUTE STOPS
These appliances are equipped with safety switches to protect against overheating and fires. Check that it is level and not tilted. The fan must also be operational. Based on the limited information provided, I can only offer these suggestions.
Dec 06, 2013 | Heating & Cooling
Goodman GDS80904BXBB keeps locking out
Clean the flame sencor , or ot could be the pressure switch blow down the hose they may be blocked .
Mar 20, 2013 | Heating & Cooling
Spa heater
You probally hear the fan at start up. If the heater won't fire the unit will shut down. This is probally an ignition problem or something in the safty circut. If you have your book on this it should have a trouble shooters guide. If your not comfortable with a box full of fire you may want to get a service person out.
Feb 10, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Fire stoppes and fan still runs
1st take a air gun and blow in the fan to clear of debris. 2nd make sure to push your reset button on the back by your fan. Last you can calibrate your flame/heat by removing the fan housing & you will find 2 set screws try a small 1/16 turn on them and try to run, should run better for you.
Oct 09, 2009 | Master Heaters BLP375AT
I have model#2509622 Williams wall heater. I just installed it and the pilot lights fine. There is a copper ground wire, but the only way the furnace will fire up is when the ground wire is in contact with...
can you manually fire the unit w/o the thermostat by shorting 2 of the 3 wires, there may be more wires than that, but you should be able to fire it on 2 to 3 wires alone let me know it sounds like something is floating voltage wise on the unit
Oct 09, 2009 | Williams 1403622 Gas Compact Heater
Blowing smoke immediately prior to auto-shut-off
Try a new CAD falme sensor, or high limit control, both very cheap.
Jan 07, 2009 | Reddy R155D Utility Heater
DOESN'T FIRE - 1 BLINK CODE
if the unit fires-up but drops out soon after then you main burner flame sensor is not working
Nov 25, 2008 | Goodman GDS80904BNA Open Flame Heater
Heater/fan issues
There is a safety switch which will shut the heater element off if the fan doesn't run. If the fan doesn't circulate air, the element would overheat and could possibly start a fire, so the switch will shut the element down. I'm not familiar with this heater, but I would check to make sure the fan is operating and also check for any filters that may be plugged and restricting air flow. If anything interferes with the air passing through the heater, the overheat switch will shut down the element. That's the best I can do from here. Good luck.
Feb 28, 2008 | Vacuums
Cozy (W352E) Heater Logo
102 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
