Question about Dryers
No power on dryer DCVH515EF0GG
Circuit breaker is not tripped. i get no power at all on dryer. is there a fuse inside dryer?
    Scholar:
  • 111 Answers
No, You probably have loose and burned up wiring at the terminal block where the cord attaches to the dryer.
Posted on Dec 16, 2008
Dryer wont heat blows cold air
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Roper Dryers
Hello, my maytag neptune dryer runs, but will not dry. where do i find the serial # ?
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. serial # should be inside door jamb!
Jan 01, 2010 | Maytag Dryers
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
Dec 31, 2009 | Kenmore Dryers
No heat gas kenmore gas dryer
Dryer will not heat up
Hi fairiesinfli,
Check the below:
Heating element
Thermal fuse
Regards
R.K.
Oct 22, 2009 | Whirlpool Dryers
Dryer does not heat
Heating element
Thermal fuse
Wiring
Aug 07, 2009 | Dryers
Heating element
Thermal fuse
Wiring
Aug 05, 2009 | Dryers
My dryer runs but will not heat. The timer sometimes gets stuck.
Jul 03, 2009 | Dryers
Not heating
Heating element
Thermal fuse
Wiring
May 20, 2009 | Dryers
Gas dryer is not heating
Heating element
Thermal fuse
Wiring
Thanks Repairclinic
Aug 25, 2008 | Dryers
Dryers Logo
91 people viewed this question
Top Dryers Experts
Marvin
Marvin
