Question about ASUS VIA KX133 Chipset K7V (K7V/500/SWA) Motherboard
Need to reset Asus k7v bios
I have a Asus k7v motherboard with disfunctional mouse/kybd inputs. My son disabled usb support in bios. Is there a way to reset the bios back to factory settings without needing an input device? Thanks
  • lmscorp Dec 17, 2008
    I really appreciate the assistance you guys provide. I feel like I have some support here!! Removing the battery did not change the contents of the BIOS... the USB's were still disabled. HOWEVER, on page 61 of the manual it's written, "Forgot the Password?" in the BIOS section... it explains about shorting the CLRTC solder pins (not a jumper) on the motherboard to reset the password in the BIOS. It turns out, it resets the whole BIOS!!!!!!!!!!! The USB ports work now. Thanks you guys!!!
    President:
  • 2,351 Answers
Hi lmscorp, to clear the cmos/bios find the cmos battery which is to the right of the main ATX 20-pin power connector & near right edge of the motherboard. Just above the,
CHA_FAN, (Chassis 3-pin Fan connector).
You can download the manual directly from Asus. Click on this link:
http://support.asus.com/download/download.aspx?modelname=K7V&SLanguage=en-us
You'll find the cmos location on page 14. You'll also need Adobe PDF reader to view the manual. Download Adobe from here;
http://www.adobe.com/products/reader/
The manual does not show a clear shot of the cmos jumpers. You may need to remove the battery completely for 10 seconds. While the battery is out check its voltage. If it measures under 3volts replace it.
Good lucl lmscorp!
Thank you for using fixya
Mike
Posted on Dec 16, 2008
  • 68 Answers
Yes, if you consult your motherboard manual this will show you the location of the cmos battery and reset jumpers. You can either move the jumpers from pins 1+2 to 2+3 and then back again after a few seconds or remove the cmos battery for a few seconds. Make sure your pc is off!
Freezes on the press del to enter setup screen
If you are using a USB mouse and keyboard then the most likely problem is a failed USB controller on the motherboard. And as your motherboard is old and was never very popular you will be hard pushed to find a replacement. Although you could try fitting a PCI USB card to use your input devices. It looks as if you will need a new motherboard, processor and RAM.
Mar 24, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
P5n-e sli usb ports error 43
You get this error code if there is an issue with the drivers.
Look here:
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/usb-ports-not-working-error-code-43/ce6662bf-cfad-4380-a274-709bf072e3d7
Here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5N-E%20SLI&p=1&s=22
Please select your windows system.
You probably need to download the chipset driver.
Open the folder, and click on global for download.
Unzip the file before you install the driver.
Look also in the bios setup, for the usb settings.
Try also to download the manual.
Try also to upgrade the bios.
Hope this will help you
Jan 31, 2013 | ASUS P5N-E SLI Motherboard
Supermicro SuperServer 5013G-M - PS2 error
Hello here is the homepage:
http://www.supermicro.com/products/system/1u/5013/sys-5013g-m.cfm
Is your Mouse a USB mouse or is it a HYBRID Mouse? Look at the bottom of mouse and see what is written. It should give you the: (1-) Name (2-) Model Number & it will either say: "USB Mouse" or "USB 2.0 and PS2 Compatible". If it is USB 2.0 and PS2 Compatible, then it is a HYBRID MOUSE - You should have a - USB to PS2 - Adapter that came with the mouse.
Use that adapter and plug into the PS2 Mouse port - (only if it is a HYBRID). It will automatically configure itself as a PS2 mouse. Now you will have both your Input devices set as PS2.
(2) - If it is a USB mouse, can you obtain a PS2 mouse to temporarily use? If you can; try using the PS2 Mouse Port?
Now you may have to set BIOS on - with regard to:
(1) - Legacy USB Support -(Either Support or Disable)
(2) - USB settings to what Motherboard supports
Try also to upgrade the drivers/bios, if nessesary.
SET LEGACY USB SUPPORT TO "DISABLED" FOR BOTH MOUSE & KEYBOARD IN BIOS.
Good luck
Nov 24, 2011 | SuperMicro Computers & Internet
USB mouse suddenly stop working it power off when reconnect the power is on however "all" usb mouse arent working. try 3 different USB mouse not working except PS 2
You need to reset the cmos settings.Pull out the BIOS battery and then you wait for 1m and then you can put it back.But you need to put the bios in right order to work correctly
Dec 02, 2009 | ASUS P5KPL-AM SE Motherboard
Mouse and keyboard not working on it(asus a8n-e)
1)Make sure the jumper that resets the board, is on the right position based on manual.
2)Reset memory stick(s)
If this does not work, try using USB keyboard and mouse.
N Sabre
Good Luck
Nov 07, 2009 | ASUS A8N-E Motherboard
USB MOUSE x PC BOOT
Could be a problem with your system BIOS, enter the setup while your computer is booting (before it gets to windows) by hitting the F12 key probably. Make sure that the boot order is HDD first, not something else.
Aug 31, 2009 | Laser LX710 Keyboard and Mouse
USB does not at booting time on bios
hi buudy first of all
1 just check whether the usb setting shows in ur bios enable it if it shows disable
2 start the pc go to device manager in my computer enable the usb device
3 to check whether it is enable plug any usb devices (keyboard , mouse etc ) if key,mouse starts than it is okayyyyyyy
Dec 06, 2008 | ASUS P5L-MX Motherboard
Asus P4p800 se Mainboard USb Ports not working
it would seem that you are not the only one with this problem with the USB's, the only soloution i have found that people say works is to reset the cmos (remove motherboard battery without any power cord attached) for 10 mins, or, go into the bios and reset to default/optomised defaults
hope this helps
kind regards
Nov 18, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Probem with Asus P5W DH waking back up
Do you have a modem plugged into phone line - is a signal on phone line causing it (unplug phone line cable to try that).
Could be faulty power switch on front of computer where the contacts are only a hairs breadth apart and the slightest movement/vibration causes it to contact (try this by disconnecting those two wires from the motherboard
I'd try disconnectng any communication cables from the computer first. That would be LAN and Modem cables. If it still restarts, disconnect the keyboard and power down the PC. If it still restarts, then power down again before it is fully off, remove the mouse. If it still does it get a priest to do an exorcism
Dec 15, 2007 | ASUS P5W DH Deluxe Motherboard
Upgrading processor
really it depends on your budget and your wants , if your a serious gamer i recomend pentium its good with the graphix rendering but if your a office and media person AMD is for you very quick with converting too! thanx please return the favour with a posetive rating
Nov 29, 2007 | ASUS VIA KX133 Chipset K7V-T Motherboard
ASUS VIA KX133 Chipset K7V (K7V/500/SWA) Motherboard Logo
320 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
