Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven won't work
Hi! The stove top works fine, but the oven bake and broil will not heat up. Both quit working just today. Do you think it could fuses?
  • figonifamily Dec 16, 2008
    Hi!
    The model number is 790.95032503. It is a Sears Kenmore stove and is only about 1-2 years old.
    Thanks so much! Carol
  • David Johnson
    David Johnson May 11, 2010
    I am impressed jyackle5 is an awesome member...Your on the ball...Wow.
We have a similar problem with our electric range. I am curious as why both the broil and bake elements went out at the same time?
Thanks.
Posted on Apr 22, 2010
  • shawn_ar Apr 22, 2010
    Sorry that I have put my question mistakenly under "Solution". This is my first time using the site and need an expert opinion.
  • 8,197 Answers
It sounds like your heat ignitor went out. To find out open the door and look for a 1/4" rod that starts in back and wraps to front then to back again that is it. shout door turn on oven to se if that get bright red I would start at 475 degrees. If it does not get bright red it went out and needs to be replaced. If I get model # I can get part # and manual to show you how to replace it. Or you can cal out an appliance repair man.
Good luck.
Posted on Dec 16, 2008
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
New installation, does not heat
I think your ignition does not work.
Is this a brand new oven ?
Does it have a stove on top ?
does the stove work ?
Dec 28, 2007 | GE Profile JT915 Electric Single Oven
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Oven won't heat
quite possibly the element burnt out .
Sep 22, 2017 | Dacor MCS230SS Millennia Electric Double...
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
350 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
