Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool side by side refigerrator light stopped working even
With new light baulb
  • Anonymous Dec 18, 2008
    tHE FREEZER LIGHT DOES WORK BUT THE LIGHT ON THE CONTROL DOES NOT COME ON.
  • 725 Answers
1 does the light on the control come on when you open the door ?
2 does the freezer light work?
3 if yes to both then...the control board (light control) is faulty
Posted on Dec 17, 2008
REPLACED BAULB AND RED LIGHT BLINKING AND WILL NOT COME ON
Look first to see if lamp went in correctly, on most sets if look carefully you will be able to see if lamp fires up for even a few moments or not.
The lamp is powered by a ballast and that could also be bad, the place where it connects (usually two pins) goes directly to the ballast.
If issue is different from before the lamp was replaced you may have a new lamp that is bad, its rare but can happen.
Dec 23, 2012 | JVC Tv Lamp Ts-cl110uaa Hd-61g887 Hd61g887...
My drivers side brake light does not come on, I replaced the baulb and it still noes not work. The same bulb does come on with the parking light. Any I can do next?
on the earth wire generaly black put ajump wire to the body and test. or check the power feed with the brake pedal on using a test light. this test will show you if it is a faulty harness wiring.
Dec 02, 2012 | 2008 Nissan Sentra
How do you change low beam on 2001 olds aurora
just reach behind ull see the electric connector plug on the back of the headlight twiste it counter clock wise it come out make sure u wear clothes on the new bilb cause if u toch the baulb itll pop on u when u turn it on btw i believe its a 9006 baulb
Jul 14, 2011 | Oldsmobile Aurora Cars & Trucks
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE refrigerator is the worst product I have even
Well, i have to jump right in here and agree with you. I have been working on appliances since 1971 and GE is the most frustrating, highest priced replacement parts ( for the most part ) of all brands. Of all the brands, Whirlpool and Maytag have been the longest lasting, best priced and easiest to work on. I truly feel sorry for you....really.
May 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Signal lights do not work.
check fuse and turn signal flasher
Mar 01, 2009 | 1992 Oldsmobile Cutlass Ciera
Whirlpool side by side just stopped working,
The only logical conclusion to this is that the fuse is blown in the plug or on the fuse board. Even if the motor expired the light would still work. Have you checked the plug/fuse and board or even tried plugging the appliance into a different outlet?
Oct 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker Stopped producing ice
What is sounds like is somehow either the water delievery system is clogged or frozen. If your getting water out of the door, then it is probably frozen. If you are able to turn off the freezer for a bit, that would be an easy way to see if that is the problem without having to deal with Whirlpool or a handyman.
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrig ED22DQ
THERE IS A NEED TO CALL A TECH IT MIGHT BE A WIRING PROBLEM.MOHAMED
Jul 14, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
