Question about Canon PC1061 Copier
Adding toner I just bought a Canon 6035 copier. I can't figure out how to add toner. Help
  • 62 Answers
The canon PC 1061 copier uses a L-50 toner cartridge. There is no toner hopper in it for u to replenish U need to slide the plate to the left hand side and open the toner hopper door to replace the toner .
Posted on May 21, 2007
  • Martin Griffith
    Martin Griffith May 21, 2007
    sorry, i mis informed because of the model machine, there is a toner hopper.
  • 163 Answers
Inside the front cover on the top right, is there a toner hopper that swings out? From the looks of the repl toner, it should be a sealed hopper. When the cartridge is locked onto the hopporit will release the latch for the toner hopper. There are usually very simple pictures on the inside of the door or toner box.
Posted on Mar 23, 2007
  • John Byse
    John Byse Mar 23, 2007
    After posting I noticed you listed under PC series... Which do you have?
SOURCE:
Canon 6035 keeps telling me to add toner when it is already full...error goes away after i open and close the hopper door..this seems to happen after every 5 or so copies(sorting and stapeling)
How do you know it's full? Did you record the copy count when you put the toner in? The only time the copier will indicate that it needs toner is when the developer unit is empty or if the toner sensor is not in contact with toner, you should hear a very high pitch squeal sound coming from the copier. If you are sure you have toner inside the developer unit then the toner sensor is bad. Does shaking the developer unit back and forth a few times help? Maybe the toner has developed a cave inside where the toner is supposewd to be touching the toner sensor.
Jun 23, 2011 | Canon NP 6035 Copier
How do you replace toner for canon np 6035 copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
May 15, 2010 | Canon NP 6035 Copier
Close but the toner container is replaceable, you do not have to pour any toner in the container. The replacement toner should be the exact same toner bottle, all you have to do is just swap out with the old one.
Mar 26, 2010 | Canon NP 6035 Copier
I have a message about the wate toner being full
open the right side of cover & then remove the west toner box
Nov 16, 2009 | Canon NP 6035 Copier
Error code E000020-0000 in cannon ir5000/6000
Main cause: The machine is not receiving toner properly because 1)The hopper connector is left disconnected. 2) The hopper motor (M9/M10) is faulty.3) The toner sensor (TS1/TS2) is faulty. 4) The DC controller PCB is faulty.
If you recently added toner, recheck that area.
Basically the copier is trying to add toner and is not getting it.
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Out of toner
check toner sensor
Jul 08, 2009 | Canon NP 6035 Copier
Adding/changing toner
You can get an operators manual from www.usa.canon.com. It can be a difficult website to navigate.Good Luck
Mar 26, 2009 | Canon imageRUNNER 210S Copier
CANON 6035
Hello my name is Nenad Kalezic from Serbia,Vrsac i have CANON 6035. I need service manual for this model. Please help me
Feb 25, 2009 | Canon NP 6035 Copier
Faded black and white print out (Canon NP 6035/6028)
Are you getting a E0020 code? If not there is nothing wrong with the hopper. Has the OPC unit been replaced recently? Also, have you looked at the developing unit? Dose the developer Mag. roller have a even coat or brush on it? If not have you cleaned the S-Blade or doctor blade? Also, have you cleaned the optics?
Aug 13, 2008 | Canon NP 6035 Copier
Canon PC1061 Copier Logo
100 people viewed this question
Clive
Clive
old marine
old marine
