Question about Midland 75-517 (14 Channels) 2-Way Radio
Need manual for Midland 75-515 FRS Speakeashy Ultra
I have the Midland 75-515 FRS Speakeasy ultra walkie-takies. Have mis-placed the manual. Can you help?
    New Friend:
  • 109 Answers
Howdy from South Texas and Merry Christmas;
While I did not see any radios with the model number you mentioned here is a lik to the Uder Manuals on Midlands website.
Patrick Patterson
Posted on Dec 16, 2008
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
Nov 10, 2013 | Midland Radio Midland X-tra Talk Frs/grms...
Walkie talkie frequencies
The Midland LXT328 is a FRS/GMRS radio and can communicate on 22 different frequencies. Here is a list from radio reference:
1 462.5625
2 462.5875
3 462.6125
4 462.6375
5 462.6625
6 462.6875
7 462.7125
8 467.5625
9 467.5875
10 467.6125
11 467.6375
12 467.6625
13 467.6875
14 467.7125
15 462.5500
16 462.5750
17 462.6000
18 462.6250
19 462.6500
20 462.6750
21 462.7000
22 462.7250
Sep 11, 2013 | Midland LXT328 Two Way Radio
How many watts do midland walkie talkie xt20 have?
These are FRS/GMRS (Family Radio Service/ General Mobile Radio Service) radios. The legal power limit for FRS is 500 milliwatts - or 1/2 watt. GMRS on the other hand is limited to a much higher 50 watt level. The wattage you transmit determines if you need to have a GMRS license. Most GMRS radios are in the .5- 5 watt range however.
The likelihood of your XT20 being a 1/2 watt out on both FRS & GMRS is very good. For Midland (or anyone else for that matter) to produce a radio with a 1 watt output that can run on just 3 "AAA" batteries would be quite the feat! If Midland did do this, the radio's battery life would extremely short. To balance the needs of light weight and battery life, output power needs to be reduced.
Claims of 20 miles is crazy. If you had these radios on mountain tops 20 miles apart - with a clear line of sight between them - MAYBE - you could hear one on the other. This would need to be done under only the most ideal conditions. The actual distance you can expect to get out of a pair of any brand FRS radios in "real world" conditions (line of sight blocked by trees and buildings) is about a mile.
An FRS/GMRS radio limited to 1/2 watt output when used on a GMRS frequency that is close enough to access a GMRS repeater system could easily cover 20+ miles. The key here is having a license and access to the repeater. Repeater owners take a dim view of unlicensed users access their repeater.
Channels 1 thru 7 are FRS and GMRS. That is, if transmitting .5 watts, you can use it as FRS. If transmitting more than .5 watts, you will need a valid GMRS license.
Channels 8 - 14 are expressly for FRS. Only .5 watts transmit power is permitted.
Channels 15 - 22 are expressly for GMRS at any transmit power up to 50 watts. Even if transmitting .5 watts, you MUST have a valid GMRS license on these frequencies.
I know - more infor than you wanted and no vclear cut number for wattage - but there's no info on these radios on Midland's site or anywhere else that I could find. Good luck!
Jun 16, 2012 | Midland XT20 Two Way Radio
Oops, misplaced my manual for my Midland LXT walkie talkie radios. How do I get a specific channel to use. When I push the scan button it goes thru channels 1 thru 22 but how do I stop it on a specific...
Channels are selected by tapping the center button once then using the arrows. The next tap of the center takes you to the CTCSS, DCS, and other functions follow. When scanning simply tap the transmit button and it should stop on the selected channel. Channels 8-14 are FRS channels at 500mw. These are the preferred channels to use for most people. 1-7and 15-22 are considered GMRS and requires a FCC License. Many people have been known to use these channels without having the license. This form of pirating is not recommended. I have included these links which could be of help to you.
To find a PDF Manual for Midland LXT310:
To locate information on obtaining a GMRS license:
Aug 18, 2010 | Midland LXT310 2-Way Radio
Need manual for GMRS FRS 04A08 cannot get radios sound on. Do you have instructions?
Here is the user guide for the Motorola Walkie Talkie you have.
Please save a copy to your hard drive or produce a printout so that you have a hard copy. This will be very useful if you need it again in the future.
Oct 29, 2009 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Motorola T5728 walkie talkie freq mismatch
Unfortunately the T5728 is not compatible with the US FRS (family radio service) frequencies. The T5728 operates between 409-410MHz. The FRS radios operate between 460-470 MHz. FRS frequencies are license-free frequencies for use in the US, as regulated by the FCC. Other countries have differing rules and thus their frequencies assigned to family usage differ.
Apr 09, 2009 | Motorola Walkie Talkies 2-Way Radio
Motorola talkabout ta288 walkie takie
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Dec 24, 2007 | Motorola Walkie Talkie 2-Way Radio
Midland 75-517 (14 Channels) 2-Way Radio Logo
1,634 people viewed this question
Top Midland Radio Communications Experts
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
