Question about Intel Play QX3 Monocular Microscope
I have QX3 computer microscope installed on my vista but it doesn't work
  • 4 Answers
I could not find driver. I placed in Windows 98 compatibility mode on my Vista. I right click Intel Play shortcut...go to "Open File location". Find QX3 application....right click. Go to properties...Compatibility tab and choose windows 98 / Windows ME. Click ok. Worked for me hope it works for you!
Posted on Aug 10, 2009
SOURCE: qx3 miroscope
Email Digital Blue and they will ask for your email address and shipping address. Looks like they're starting to send out the Vista version on cd via the mail, then make it available online for download later. Best of luck!
Posted on Feb 05, 2008
  • 72 Answers
SOURCE: QX3 micrscope dont work with Vista
Uninstall the existing Intel microscope software and then follow the steps below.
Instruction for installing the QX3 or QX3+ Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Posted on May 24, 2009
  • 72 Answers
SOURCE: vista driver for Intel QX3 Microscope
  • 72 Answers
SOURCE: need vista drivers for QX3
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Vista.
Before you run the programs below, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/qx3plus
or
http://downloadcenter.intel.com /Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419& amp;strOSs=All&OSFullName=All%20Operating%20Systems?=eng
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
http://tinyurl.com/IntelQX3driverXP or
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Posted on Jul 24, 2011
  • 72 Answers
SOURCE: is the qx3 microscope usable on a vista system.
or
Windows 7 driver
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
Step 1. Download and install the QX3PLUS.EXE software from:
http://tinyurl.com/QX3-Win7-Files
IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok".
Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run.
If you get a message that the microscope is not plugged in, quit and restart the program.
If the program hangs or crashes, reboot the computer, then restart the program.
Comments and suggestions to mmehall [at] yahoo.com
Jan 19, 2014 | Intel Play QX3 Monocular Microscope
Digital blue qx3 drivers
May 02, 2013 | Intel Play QX3 Monocular Microscope
I was given QX3, not QX5 software with instructions in German. My computer is windows 7. should I still install the two intel play disks which came with the computer microscope. Can I install it as...
Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 5. Now double-click on the QX3+ icon on the desktop and the program should run.
Mar 26, 2013 | Intel Play QX3 Monocular Microscope
Need vista drivers for QX3. had it on my old win 95 computer, but need to install it on my new vista machine. Are there vista drivers for the Intel Play Qx3 microscope?
or
Jul 16, 2010 | Intel Play QX3 Monocular Microscope
My QX3 worked wonderfully on my XP system, but I can't load the drivers/installation files on a Vista system.
Sorry, Intel stopped making these years ago. They DID post updated drivers, but long before Vista arrived. Go to the Intel web site, your only other hope is to find a blog of Intel QX3 users, maybe some gearhead updated the driver pro bono.
May 14, 2010 | Intel Play QX3 Monocular Microscope
Have QX3+ driver for my intel play microscope but poses a problem
Uninstall the existing Intel microscope software and then follow the following instructions:
Mar 23, 2009 | Intel Play QX3 Monocular Microscope
Vista driver for Intel QX3 Microscope
Jan 10, 2009 | Intel Play QX3 Monocular Microscope
Dec 16, 2008 | Intel Play QX3 Monocular Microscope
I need the driver for my Intel Play QX3 for Vista
This works on my Vista system.
Instruction for installing the QX3 Microscope with Vista
Step 1. Install the QX3+ downloaded from Intel:
Step 2. Download and install the QCODINSTL Codecs software from:
Oct 26, 2008 | Intel Play QX3 Monocular Microscope
Qx3 miroscope
This worked for my QX3 on my Vista computer!
Feb 01, 2008 | Intel Play QX3 Monocular Microscope
Intel Play QX3 Monocular Microscope Logo
1,305 people viewed this question
Top Intel Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
