Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
I have a gas oven whirlpool sf3020ekq2 buners work but oven won't
We have had this stove since we moved in about 4 years ago. I never had cooked with propane before but it seemed fine at first and over the last couple of months when we turn on the stove part to bake it take a long time for the oven to start and so when we started to smell gas and the oven still not lit then we would slam the door hard and it would come right on well even that is not working. i really hate this stove!!
  • 306 Answers
Sounding like your hot surface ignitor is getting bad. What I would like for you to do is open the oven and take the bottom panel off. This is so you can see the hot surface ignitor. Turn the oven on and look at the hot surface ignitor it is down on the bottom right next to the burner assembly. Does it start to glow and turn cherry red? This ignitor isn't too hard to replace couple of small screws and two wires. Will have to cut the wires so disconnect the unit from the 120 volt plug. Now if it starts to glow and get cherry red hot then the gas valve is sticking and it is the one going bad. That is a little tougher to replace. Turn the gas off at the source and get your wrenches unscrew the gas valve small space so if you want remove the door by just pulling it off the hinges.
If unit is old and you don't like it anyway maybe santa would be good to you and replace the stove oven. The gas valve is about 60 bucks or so and hot surface is about 20 bucks. let me know how it turns out.. ken
Posted on Dec 16, 2008
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
I have a whirlpool stove that is gas the display won t work so cannot use oven.
It's likely that the board on which the display is found also contains the control electronics for the oven functions.
If you want to look into replacing this yourself, go to the link below for illustrations of your unit but the page lists several variations beyond the model number you listed so check your literature from your unit to establish which exact unit you have:
Whirlpool range
Sep 16, 2011 | Whirlpool SB160PEE Gas Single Oven
Have a frigidaire gas stove has worked great for 6 years. Now we are getting a strong smell of gas when it is heating up or cooking. Have checked to make sure flame is on and it is. It also seams like it...
Try changing out the regulator for the stove. Does the flame seem weaker than it used to? If so, your regulator is probably going out and the gas you smell is the residual leaking out when the stove is on.
Jul 01, 2011 | Frigidaire Ovens
My 3 year old barely used Whirlpool Gas Oven has stopped heating. The gas stove top still works. Whirlpool customer service told me to clean out the gas chamber with a pin...there's nothing TO cleanout....
Just had a repairman here today March 31, 2010 for the same problem. $350 repair bill. There was a short in the gas valve that cause it to go bad and it also blew out the ignitaion computer board. Forget about replacing the ignitor. I already did and that was not the problem. So the qauestion for you is pay for the repair or buy a new stove.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Gas range..surface buners light...oven does not.
Usually the gas valve is behind the stove. pull it out from the wall and look behind it. Code requires the shut off valve to be in the same room as the stove so if there is no shutoff valve it would be a good idea to call your gas supplier and have them take a look at the problem. They will look at it and advise you for free.
Mar 31, 2009 | Ovens
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Jan 24, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White Logo
206 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
