Question about TDV Vison TDV FV19B 19" Flat Panel LCD Monitor
Monitor power light is blinking and cannot see anything.
My monitor power light is blinking and the monitor does not display anything.
  • diptipatel17 Dec 16, 2008
    can someone please help
  • mcpat Jan 03, 2009
    Same problem. Worked fine until I tried to adjust the contrast/color and it started rolling by in colored pages. Turned it off then it wouldn't come back. The computer thinks it's contacting the monitor but the screeen is black. Already tried unplugging and rebooting everything. Also tried downloading new drivers for connector but still nothing. Any ideas? It's less than a year old and should still work.
  • 19,396 Answers
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
5 Suggested Answers
SOURCE: Medion MD7317 17 inch Flat Panel Monitor
My MD7317 did the same thing until I actually installed the driver for it. My windows did not have the correct driver in it's driver base, so I found the driver online ( took a few minutes of searching) and within a few minutes of installation the monitor displayed a great colorful picture. Naturally, I had to use another monitor while I was searching. Driver is about 3.3 megs. It came in a zip format. I did not keep track of the link to driver, but it omly took a few minutes to locate it.
Posted on Sep 03, 2007
  • 31 Answers
SOURCE: When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why ....
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Posted on Mar 30, 2008
REPLACE THE 3-470UF 25V CAPACITORS WITH R-SHACK
470UF 50V CAPS WORK GREAT!!!!!!!!!!!!!!
Posted on Apr 07, 2008
  • 3 Answers
SOURCE: THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
power led green is blinking
Posted on Jul 27, 2009
My monitor is blank. The power light is blinking ...
Throw it Away and buy a new one (its cheaper)....
May 14, 2010 | Computers & Internet
No display on monitor when powered,Light is on.
change caps 1000mf-10v to 1000mf-25v in power supply and 470mf-10v to 470mf-25 or 16v.
May 12, 2010 | ViewSonic E50C 15" CRT Monitor
My dell e173fp monitor has quit working. The power light continually blinks when power is applied, even without having to turn it on. An identical substitute monitor works fine on the computer system. ...
Is the power blinking amber? This is a DPMS power-save mode. With the computer disconnected and the monitor on, do you see the colored self-test block floating around? With the monitor on, computer connected, and you still have no image displayed, take a bright flashlight and examine the screen closely. If you can see a very dim display in the screen, the fluorescent tubes which light up the *background* and provide the vivid picture(sort of like a how an x-ray picture viewer works) are defective. The power light blinking may be the power supply sensing the non-functioning tubes or it could just be bad. If your display is under warranty, replace it. If not, trying to have the monitor repaired for this type of problem is almost as costly as a new one--and there won't be an active warranty on anything else that might fail. Hope I helped you.---Rick
Sep 10, 2009 | Dell E173FP 17" LCD Monitor
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
Mar 29, 2008 | Computers & Internet
TDV Vison TDV FV19B 19" Flat Panel LCD Monitor Logo
408 people viewed this question
Top TDV Vison Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a TDV Vison Computer and Internet Expert? Answer questions, earn points and help others
