Question about Roper RAX7244KQ Top Load Washer
Washer makes a loud noise while trying to spin
The washer doesn't have a problem filling or draining. When in the spin or agitate cycle, it just makes a very loud noise and will not do anything. This is a direct drive unit and doesn't have a belt to tighten. I'm not sure what it is. Can you help.
Buy a quality washer
Posted on Dec 29, 2007
  • 67 Answers
The problem most likely what it sounds like is the motor coupler which cost somewhere around 20 bucks from a repair store or parts place. the motor coupler sits between the motor and the transmission and transfers motion from one to the other if its making a loud clicking sound that sounds like gears then thats it and you'll be surprised to see that its simply made out of rubber and plastic. Its a little bit of an advanced repair make sure to unplug the washer because u will have to drop the motor off to take the coupler off the transmission parts required flattip phillips head 1/4 nutdrive and something to put over the coupler to bang onto the motor and to the transmission. Gl its really not that hard a professional can do it in about 15 minutes it might take u an hour maybe make sure to take the whole cabinet off do not try to take it apart from the back
Posted on Mar 20, 2007
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
Dec 14, 2008 | Kenmore 22422 Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Roper RAX7244KQ Top Load Washer Logo
188 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
