Question about Intel Play QX3 Monocular Microscope
QX3 micrscope dont work with Vista
I have vista and also I installed QX3 microscope. I didn't get any problem while I was installing the software but after I connected QX3 Microscope and when I try to open on my PC Its just showing the logo of Intel play and after that it stops. I am unable to work with it
  • Anonymous Mar 14, 2009
    I have Vista, QX3 and no software to work with!
    Sniper:
  • 72 Answers
Uninstall the existing Intel microscope software and then follow the steps below.
Instruction for installing the QX3 or QX3+ Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Posted on May 24, 2009
  • 4 Answers
I installed the exe file and then ran on windows 98 compatibility mode. Worked for me!
Posted on Aug 10, 2009
Is there a free download so I can run my Intel.Play Qx3 Microscope in Vista
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Vista.
Before you run the programs below, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/qx3plus
or
http://downloadcenter.intel.com /Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419& amp;strOSs=All&OSFullName=All%20Operating%20Systems?=eng
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
http://tinyurl.com/IntelQX3driverXP or
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Jul 06, 2011 | Intel Play QX3 Monocular Microscope
Need vista drivers for QX3. had it on my old win 95 computer, but need to install it on my new vista machine. Are there vista drivers for the Intel Play Qx3 microscope?
or
Jul 16, 2010 | Intel Play QX3 Monocular Microscope
My QX3 worked wonderfully on my XP system, but I can't load the drivers/installation files on a Vista system.
Sorry, Intel stopped making these years ago. They DID post updated drivers, but long before Vista arrived. Go to the Intel web site, your only other hope is to find a blog of Intel QX3 users, maybe some gearhead updated the driver pro bono.
May 14, 2010 | Intel Play QX3 Monocular Microscope
Is the qx3 microscope usable on a vista system. and where do you get the qx3 bulbs?
or
Feb 23, 2010 | Intel Play QX3 Monocular Microscope
I have play Qx3 from my friend and i have windows vista and when i tray to make it work my pc say that it cant find all the necessary software components plz reinstall Qx3 software (85) so what can i do
or
Nov 15, 2009 | Intel Play QX3 Monocular Microscope
Have QX3+ driver for my intel play microscope but poses a problem
Uninstall the existing Intel microscope software and then follow the following instructions:
Mar 23, 2009 | Intel Play QX3 Monocular Microscope
Vista driver for Intel QX3 Microscope
Jan 10, 2009 | Intel Play QX3 Monocular Microscope
I need the driver for my Intel Play QX3 for Vista
This works on my Vista system.
Instruction for installing the QX3 Microscope with Vista
Step 1. Install the QX3+ downloaded from Intel:
Step 2. Download and install the QCODINSTL Codecs software from:
Oct 26, 2008 | Intel Play QX3 Monocular Microscope
Qx3 miroscope
This worked for my QX3 on my Vista computer!
Feb 01, 2008 | Intel Play QX3 Monocular Microscope
Need drivers for intel qx3 microscope i have vista os
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will notice see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Dec 03, 2007 | Intel Play QX3 Monocular Microscope
Intel Play QX3 Monocular Microscope Logo
1,769 people viewed this question
Top Intel Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
