Question about GE JGSP23 Gas Kitchen Range
Oven not working, GE JGSP23
User guide says to locate oven shut off valve on pressure regulator of self-cleaning oven and move shut off valve to open. Nowhere in the guide does it tell you what the regulator looks like or where to find it.
  • Anonymous Feb 16, 2009
    oven's not working, I removed the drawer, but how do I switch the pressure regulator on?
    Scholar:
  • 111 Answers
You need to remove the draweer unde rthe oven. The regulator wil be against the back towrds the left side. What is it not doing?
Posted on Dec 16, 2008
Bake does not work
you need to call a repair service we do not recommend DIY with gas appliances.Safety reasons
Nov 02, 2017 | GE JGSP23 Gas Kitchen Range
Electronic ignition for the burners does not work
Hi bd922 - Try resetting the unit by unplugging it or flipping the breaker off. While the unit is off, confirm that the shut off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. Wait approximately ten minutes and turn on the range. If reprogramming the unit proves to be ineffective contact a professional to move forward accurately. The range could possibly be experiencing a communication issue with the EOC or wiring failure.
Mar 03, 2013 | Frigidaire Gallery 30" Self-Cleaning...
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
Need ge jgsp22 gas slide-on ranges installation instructions
does the pilot light work and when you turn it up the flame should torn up if not the thermo cupler is faulty
Nov 21, 2011 | GE JGSP23 Gas Kitchen Range
I cannot unlock my door after self cleaning, it has been several days i pushed the 9 and unlock key but it will not open.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Feb 23, 2010 | GE Profile JT952 Electric Double Oven
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Jan 08, 2010 | GE Kitchen Ranges
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Ge xl44 after self clean cycle the door won't open and the display says "locked door" flashing.
or
Sep 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGSP23 Gas Kitchen Range Logo
380 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
