Question about Lexmark X1150 All-In-One InkJet Printer
MULTIFUNCTION JET PRINTER MODEL LEXMARK X83
I HAVE A PAPER JAM WICH I HAVE RESOLVED IE. GET THE PAPER OUT ETC. BUT FROM NOW ON I PUT MY 30 PAGES OF PAPER IN THE BACK TRAY AND WHEN I DO ASK FOR A PRINT THE FIRST PAGE GO DOWN AND AFTER EVERYTHING PRINT *** THE SAME PLACE.
I HAVE TRIED TO CLEAN THE PAPER ROLLS , IT DOES NOT WORK.
QUESTION: WHAT SHOULD I DO.AND WHERE CAN I HAVE THE TECHNICAL MANUAL OF THE X83 ON INTERNET.
WAITING AND ANSWER. THANK YOU
    Scholar:
  • 93 Answers
You will find the solution for this on this site
Choose the Location
then type the mode number
there is a page with the solution available for this problem
http://support.lexmark.com
Posted on Dec 16, 2008
Mf5770 Error paper jam and etc.
It sounds like a clutch needs replacing.
Oct 22, 2013 | Office Equipment & Supplies
If I schedule a print for my Lexmark X83 it feeds one sheet of paper straight through to the tray but does not print anything. No alarms anywhere on system. Same thing occurs if I ask for test print or...
Sounds like a clogged print head. In the lexmark printer software there should be a maintenance tool where you can try and clean the print heads.
By the same token the X83 is about 10 years old and well past the life cycle of most ink jet printers so if the troubleshooting tools don't get it back in order, it will be cheaper to replace than to repair.
http://www.lexmark.com/AP/service/info/multifunction/4403.pdf
Jul 09, 2011 | Lexmark X83 All-In-One InkJet Printer
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
Paper will not feed through the printer . . , ''paper jam'' message appears . How can i open the printer to check for a paper jam? I have a Lexmark X83 printer/copier/scanner.
behind the printer there is the tray that can be opened easily to check if the printer is jammed in or the paper feed sensor is stuck up.just open the back tray of your printer and check.
get back if you require more assistance on this.
thanks.
Jul 08, 2009 | Lexmark X8350 All-in-One Plus Photo with...
How do I remove the cover of my lexmark X83? The paper will only feed part of the way then I get a paper jam message.
there is a cover there at the back of your printer, pull it down then remove the paper hang on their, then after you remove , check if there is another paper to hang, after that try to print
Jul 01, 2009 | Lexmark X83 All-In-One InkJet Printer
X83 lexmark A06 error (paper jam)
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Lexmark X83 All-In-One InkJet Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark x83
Sounds like there is something like a part of a sticky address label, or a piece of other paper stuck inside.
Take a heavy piece of card stock and feed it through the paper path. Chances are, when you get the card stock all the way through, it will push out the offending object that is hung in the paper path.
May 19, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
