Question about Philips HTS3440/37 System
HTS3440 Home Theatre System
You said that you were going to have a friend look at the power supply to see what the problem is. Did you find out what is wrong? I know the HTS3450 has been identified to having certain capacitors that cause a similar problems and I wasn't sure if you had figured it out for the HTS 3440.
4 Suggested Answers
SOURCE: Philips HTS 3450 sound
I just blew my subwoofer up. The fuse was blown so I rigged it with something to act as a fuse, and the thing spewd out a volcano of smoke! Oh well..
Posted on Oct 04, 2008
SOURCE: Hts3450 Sound Gone
Here is a picture of the Power Supply PCB. The location of the 470uF 25v capacitors is marked by the red circles. To locate these the two circuit boards need to be separated. Pictured are the replacement 35v capacitors. Thank you to WheatService for discovering the solution. I hope this helps. I went to Radio Shack and got them to do the soldering for me. It cost a total of like $15. The sound works like normal now.
Posted on Oct 16, 2008
SOURCE: Region Unlock code for Philips HTS 3152
Power on the system
Eject the disk tray
Press Stop for around 2-3 seconds
Type in 7,3,4,4,6,6,0
You should get a message saying your player is now Region 0.
Posted on Oct 20, 2008
Phillips 3440 theater system. Was watching and the sound went off the subwoofer light went out and no sound at all.
It may have overheated. It also may be just poorly designed/assembled and something blew out. If you're comfortable with opening it, you could take a peek inside and see if there's any scorch marks/soot on any of the boards inside. You should also check the power supply as when they go, the whole thing will normally shut down.
Jun 04, 2010 | Philips HTS3440/37 System
Philips hts3440/37 i need to know a remote that works good with it i got it from a friend and i think its stuck on 2.1
you can use a harmony remote by logitech. once you set it up the remote will have every function as if it were the original remote. try looking at the 550 harmony not that pricy and they work great.
Oct 24, 2009 | Philips HTS3440/37 System
Sound does not come out of home theatre system
Check for power to the Home Theatre system. If you have lights on the front of the system, check your connections to the external speakers. Next check the output settings in your TV's setting menu. More info from you regarding this problem would have been helpful. I'm guessing your thoroughness is probably going to turn out to be a contributing factor.
Apr 21, 2009 | JVC Audio Players & Recorders
I have the philips hts3440/37 none of the speakers work.
Doubtful that it is as serious as a fuse, unless it was working before and now it's not.
Are you getting no sound when watching DVD's? Try adjusting the volume on the home theater system - press the SURR button until it says "Dolby" or something like that.
Make sure it is connected like this:
Feb 21, 2009 | Philips HTS3440/37 System
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
I bought philips 5.1 home theatre for PC it is not supporting
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jul 02, 2008 | Philips HTS3450 System
Home theatre
I had this same problem. All I did was switch the sound type by repeatedly pressing the "SURR." button on the bottom left corner of the remote. Usually after 10 times the sound is back,
Jan 26, 2008 | Philips HTS3440/37 System
Volume problem with surround sound
I tore mine apart, and the problem seems to be with the power supply in the sub-woofer-instead of 36 Volts, it it producing 2.6V. I'm having a friend have a look at the supply.
Sep 16, 2007 | Philips HTS3440/37 System
Philips HTS3440/37 System Logo
189 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
