Question about Sony D-EJ001 Personal CD Player
"No Disc" and grinding noise.
I just baught this new in the box, it's less than a week old. It was working fine a few hours ago, but now when I press play, it makes a grinding type noise, then reads "no disc." I have tried using different discs, new batteries, taking out battteries for a few minutes to let it reset (not even sure if that is necessary)and still no change. I then took out the screws and opened the case up, nothing seems to be loose or out of place. Any ideas?
  • scorpio65 Jan 16, 2009
    Hey, I have the same problem with my sony walkman cd player. (D-EJ001) ...I push play and it says no disc, then just shuts off. Grinding noise here too, like the cd is going to try to spin but never does. I paid extra for this thing because it's supposed to be durable, but never even dropped it.
sandrew
  • 2961 Answers
SOURCE: Won't load or play disc or dvd
It's a well known fact PS2's had a cheap lazer fitted to them, that's why when it gets chiped to play copy games, not long after it starts playing up. The lazer may just need aligning, purchase a cd/dvd cleaning cd rom as these can check audio, lazer alignment and clean the lens.
Posted on Jan 07, 2007
smithy007
  • 9 Answers
SOURCE: my psp makes a wierd grinding sound when loading umd's!
mine makes a medim-loud nosie and always have done, it doesnt affect my gameplay, nor should it stop you turning it off.
Posted on Jan 02, 2008
SOURCE: Cant Read Disc
Unsolder transit solder pad near ribbon connectors
Posted on Feb 13, 2008
ctf1800
  • 4402 Answers
SOURCE: Sony Camcorder Handycam DCR-DVD505 Disc Error C1302 after installing new Sony DVD disc in driver?
go here
Posted on Jun 11, 2008
ninexunix
  • 64 Answers
SOURCE: My Playstation 2 Console Keeps 'Freezing'
Well, you have one of two things going on. Either A.) your laser lens is dirty or B.) Your laser lens is out of alignment.
Using lens cleaner kits are useless for any cdrom or dvdrom if you're a smoker and smoke around your PS2. Reason I say this is nicotine and other resin forms cloud your lens over time and create a film on it.
By what it sounds like to me is since it's reading disks part of the time and kinda works, that your laser lens alignment might be ok. However, don't rule this out completely.
First, do a cleaning. Power on your PS2 and open dvdrom tray via the button on your console and power down the PS2 via the switch on the back. The point of this is to keep the dvdrom tray open as you take apart your PS2 so we can get at the lens. Take the PS2 apart (flip it upside down and remove the 8 screws from the bottom, 4 maybe covered up by rubber and plastic square plates so remove those to get at the screws) Next, take the top of the PS2 off and look at the DVD assembly, there should be four screws that keep the lid on the dvdrom. Remove these four screws and take the plastic plate off the top of the dvdrom. Watch this video and clean the following items:
Put your PS2 back together and test. If this doesn't work let me know and i'll go over instructions on how to align your laser lens. But i'm quite sure, by what you have told me, that this is your problem.
Posted on Nov 27, 2008
I had a constant grinding coming from front passenger tire. Replaced Caliper and put the worn pads back on for a day, the constant grinding went away. It would still grind while braking,hitting a bump
It sounds like the brake pads are metal to metal, when you turn the flexing of the wheel makes them touch the rotor and grind. This can rarely be caused by a badly worn wheel bearing as well, have both brakes and wheel bearing inspected.
Mar 02, 2017 | 1999 Pontiac Grand Am GT
I drive a 2005 Toyota Corolla and about 3 months ago I had the brake pads changed and replaced them w/ ceramic. Now, after a few stops, they make a noticable grinding noise when I apply the brakes. Is...
It is never normal for your brakes to "grind". A lil squeaky, not so bad. Grinding, not so good. I would take it back to whoever replaced them and have them checked. Ceramic pads are better pads because the stop you better and last longer than matallic pads, and the also create less dust, but they should not be grinding. It could be a sign of improper installation or a sign of bad or worn rotors. Definately have it checked out.
Aug 17, 2011 | 2005 Toyota Corolla
Grinding noise
Usually a grinding noise in a disc brake is caused from a rotor with a raised edge that froms from normal wear. The raised edge is not a big deal until you install NEW disc brake pads. All of the sudden you have a grinding noise everytime you apply the brake because the NEW disc pad is being ground down but the raised surface created from the OLD Disc Brake Pad. Most of the time the Brake repair shops turn rotors on the car when the pads are replaced and this grinding symptom does not manifest itself.
On and OLD set of disc brake pads over time that raised area on the rotor starts to flake / rust / corrode and can come in contact with the brake disc pad when the brakes are applied.
Hope this explains it well enough.
Thanks for using FixYa.
Feb 12, 2010 | 1993 Toyota Celica
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
My xbox 360 just grinded my brand new Rockband 2 disc.
The Xbox 360 is known for this. I would contact Microsoft as soon as possible.
Assistance by phone seven days a week.
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102 Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
Jan 02, 2009 | Microsoft Xbox 360 Console
DVD+RW playback problem(s)
same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
**DISCLAMER**
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Aug 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
360 grinding noise and unplayable disc
Crack open the DVD case and see whats going on and try fixing it yourself. OR Buy a new drive off of eBay and transfer the firmware key over from the old drive too the new one.
Sep 20, 2007 | Microsoft Xbox 360 Console
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
