Question about NAD C542 CD Player
Nad C542 Troubleshooting
I have a one-year-old Nad C542 player that will play discs properly for a day or two and then fail to find any track on any CD for dozens of attempts. During these failed attempts, the disc spins but will neither play when the play button is engaged nor stop spinning when the stop button is pressed. The drawer open button always works however. Any ideas? Thanks in advance. Bill
  • GaryJay Jan 22, 2008
    Same problem here. Unit stopped working right in the middle of a CD (a store-bought HDCD), and now will not track any CDs at all. Has anyone found a solution other than dealing with NAD customer service, which sounds simply awful?
  • Anonymous Mar 30, 2008
    Hi everyone, I had the same problem with my NAD C 542 cd player with the "no disk" message.  Even if I turn off the player and turn it back on the machine will occasionally display the no disk message, although the disk spins up.   Once I get it to work, I leave the machine on and  have less problems with it.  My $10 portable cd player works better than this piece of junk.  I will never buy anything from NAD.  I exchanged this for another player, with a 6/2006 mfg. date and 2 months later this second machine began to act up the same as the first.    Laser lens is clean, inside connections are tight and proper voltage is coming from the outlet and my CDs are like new w/ no scratches, oil, etc on them, so I have no idea.
    New Friend:
Found same problem with mine, solution .. place clean paper over the optic, then a magnet, leave for a few seconds, the build up of static causes a magnetic field in the optic preventing it tracking, have cured a few other brands with this as well .. shows manufactures are putting inferior parts in to their players, hope this helps !!
Posted on Apr 20, 2013
    Genius:
  • 1,175 Answers
I've worked on 2 model 512 players. Both with the same issues.
These units are **** for the money.
BAD transport.
I fixed one by changing power supply capacitors.
The other??? NAH
Posted on Nov 14, 2008
This is an issue that has plagued the 541I and 542 models - some units worked fine and some units had similar issues as the ones you mentioned. It was suppsoedly fixed beginning with Serial Number G56C54224800 but I know someone who has a later serial number and had the same issue. It could be the laser or the transport or both. Simply put NAD has a quality control issue. There products still produce great sound but the great sound at a reasonable price is seemingly coming at great cost - the lack of consistent quality.
Posted on Nov 18, 2007
    New Friend:
  • 50 Answers
THE LEASER IS WRON OUT REPLASE IT.OR TRY CLEANING IN WITH DISC CLEANER SOLUTION /DISK
Posted on Mar 24, 2007
Nad cd541i doesn't always read cd's; it can tell me how many tracks/minutes there are but won't find the beginning of the cd; in this case, sometimes if I skip forward two or three tracks and...
It sounds like a physical problem in the laser seek mechanism. Possibly a sticky area on the guides. Heavy reading for all malfunctions related to optical disc...
http://www.repairfaq.org/sam/cdfaq.htm
May 19, 2011 | NAD C542 CD Player
I get a no disc message even though there is a disc in the machine.
Hello
there are two option of such fault
1. lens is dusty, clean the lens using moist cloth/cotton 2. lens got bad need replacement
third option is CD is faulty/scratch
hope it helps. do rate if so
Dec 12, 2010 | NAD C542 CD Player
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
Nov 21, 2010 | NAD C542 CD Player
My NAD C 541 cd player will not play any discs. I open it put the disc in and it tries to scan and then rejects the disc and opens on its' own. There is the word 'over' in red below the track number...
It could be the belt for the tray mechanism. Tray closes then motor is pushed up to CD. If belt slips or physical mechanism is sticky CD will not spin and tray will reopen.
Nov 09, 2009 | NAD C542 CD Player
When i put the disc inside the cd player, the disc run during a time like 5 minutes and after this show a mesage "no disc", but the disc is insede yet. i need i help
Hello my friend, try another disk and if it fails again clean your cd player with a disk cleaner cd either liquid solution or dry. If you don't have disk cleaner try to purchase in any store you have in your area or shop at online in this site: http://www.nextag.com/cd-disk-cleaner/search-html . Further steps in cleaning cd/dvd player surf this iste: http://labnol.blogspot.com/2006/07/how-to-clean-dvd-or-cd-disc.html. And if all of the given steps are not helping then try to contact your supplier or technician in order to check if your player is working properly.
any progress to your problen you may contact me.
Thanks
Jun 16, 2009 | NAD C542 CD Player
NAD C521i four year old. Usually fails to find cd's When it does tracking and sound is bad.
I've dealt with this type issue quite a bit.
Believe it or not the drawer belt needs to be changed.
If the drawer isnt drawn all the way into the unit...the disc motor wont spin and ....you get rejected
Also the lens on the laser could be dirty.
Take it to a tech . Try a local stereo store . They should know who's best.
Happy new Years,
Scott
Dec 11, 2008 | NAD C521 CD Player
NAD C542 CD PLAYER
maybe it is just the belt for the tray motor.
Jun 27, 2008 | NAD C542 CD Player
Nad plays for a minute or so...
First thing to do is to check all your new caps and their polarities.
Capital98
Dec 19, 2007 | NAD C542 CD Player
No disc
Try using a cleaning disc, if that doesnt work take apart the unit and manually clean the lens. If that doesnt work your going to have to take the unit in for an estimate. If its more then two year old and you paid less then 150 bucks for it , it probably is not worth the estimate fee. good Luck
Aug 26, 2006 | NAD C542 CD Player
'No disc'
Most likely a general service is required.As it is under warranty, take it iommediately to their Service Centre. They will clean the lens. grease the Drive Mechanism and Tray mechanism. Should - in all probability clear up the problem.
NAD C542 CD Player Logo
1,447 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Jose Ma DM.
Jose Ma DM.
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
