Question about Verizon Communications enV2 Cellular Phone
Env2 charger wont fit in the hole and wont charge my phone
Yes it is.
It wont fit.
And wont charge at all
is it the charger the battery What?
I need HELP!!!!
I love my phone and need help!
  • gingin11235 Mar 14, 2009
    My charger fits in the hole, and it is definitelythe right charger. It used to charge fine if i just plugged in the charger, like it should work. However, about two months after I got it, it wouldn't charge that way. I had to hold the charger in, keep it pressed down with something heavy in order for it to effectively charge the battery. I'm thinking something is loose inside the phone...
    President:
  • 625 Answers
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars.
2. you can get a new phone. cost ???
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
Posted on Jul 02, 2009
  • 75 Answers
Your best bet is to take it to Verizon and see if they can see whats going on. If it used to fit, and doesnt now, something isnt right. Verizon could tell you more. Make sure the charger says LG on it, and on the other side there should be the letter B. If that B is not there, then its not the right charger. If it is the right charger, then you need to take it back to Verizon. Good luck.
Posted on Jan 13, 2009
2 Suggested Answers
GrinningFool
  • 625 Answers
SOURCE: env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
Hope that helps
LG enV2 Battery not chairging
It might be your charger or your charger port.
First check the charger by using another charger to test if it will charge.
If not charging that means your charging port is faulty needs to be changed.
Jan 21, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
I have the Verizon EnV2, & it won't charge. Is it my battery?
sounds like you have a short between the chrager and the phone... look and see if anything is bent where the phone and charger meet....if not.. call verzon your phone my still be under warranty and if it is they have to send you a new one ....of its just the charger they will GIVE you a new charger too
hopes this helps
Dec 09, 2009 | Verizon Communications enV2 Cellular Phone
ENV2 Phone will not charge and its not my charger! help please!!!
Try another battery. Those batteries usually only last a couple of years.
Aug 14, 2009 | Verizon Communications enV2 Cellular Phone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Cannot charge LG EnV2 VX91000 phone
The issue is the charger port on the ENV2 breaks fairly easily.Thefirst step is to contact your carrier to see if it is coveredunderwarranty. If it is, great get it replaced.
3.You can get an external battery charger to charger the batteryseparatefrom phone. cost about 25 dollars. Check out the following linkforones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
Hope that helps
Jun 30, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
Can't charge my enV2
Hope that helps
Mar 07, 2009 | Verizon Communications enV2 Cellular Phone
is it the right charger? if it is it may not be fitting good because the charger might not be good or the charging port on the phone take it to a verizon store.
Dec 16, 2008 | Verizon Communications enV2 Cellular Phone
My charger for my env2 will not fit in the hole thing and wont charge. I cant figure anything out and i need to charge my phone ASAP please Help!!!
I think you should go to the Verizon store and tell them about your problem. But if you've only tried putting the charger in one way, try flipping the charger over and then putting it in or put the charger in a different spot on the phone. Search until you find the right one!
Lg env2 not charging
The issue is the charger port on the ENV2 breaks fairly easily.The first step is to contact your carrier to see if it is coveredunder warranty. If it is, great get it replaced.
3.You can get an external battery charger to charger the batteryseparate from phone. cost about 25 dollars. Check out the following linkfor ones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
Hope that helps
Aug 04, 2008 | Verizon Communications enV2 Cellular Phone
Verizon Communications enV2 Cellular Phone Logo
1,762 people viewed this question
Top Verizon Communications Cell Phones Experts
ismael castillo
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
