Panasonic Viera TH-42PX80U Plasma TV Logo
Posted on Aug 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green and black screen when I use turn Direct TV box
I have a Panasonic th-42px80u that is getting a green screen when I try and watch direct tv. DVD's work fine. It started a few weeks ago it would go green for a little bit then work normal for a few days now it doesn't work at all.
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Aug 03, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292559
Points
3377
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
5 Related Answers
Anonymous
  • 790 Answers
  • Posted on Oct 02, 2007
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Anonymous
  • 4234 Answers
  • Posted on Jul 10, 2008
SOURCE: green interference on Panasonic TH-PX75U
Since the set is only 8 months old, it should still be under warranty. This may only be an internal connection problem, but opening up the unit will void the warranty. I would suggest that you call for warranty service. This is a problem with the set and has nothing to do with external devices or interference.
Keep us posted.
Dan
Anonymous
  • 505 Answers
  • Posted on Sep 07, 2008
SOURCE: Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Anonymous
  • 1779 Answers
  • Posted on May 23, 2009
SOURCE: TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
radar001
Bob Korsu
  • 1051 Answers
  • Posted on Dec 17, 2009
SOURCE: HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
I was trying to connect my ps2 with Panasonic vieara tv but picther is in black and white and no sound
A black and white picture suggests you are trying to use a composite video input but the TV may be NTSC format while your game is PAL, or the other way round. Use a game with the correct format or use the separate RED, GREEN & BLUE inputs (may require a different type of lead).
My panasonic viera lcd, model no. th-42px80u, flashes green when powered up, then a sequence of 10 red flashes. whats the problem ? joe
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Panasonic viera 42 inch plasma, comcast digital cable. screen goes totally green. switch to comcast guide, green disappeared and switched channels, then back to original channel and all was normal. it...
It sound like you are using a component video connection to the TV, which is of variable specification. Try a different type of video feed from your Comcast box
3helpful
Screen turns bright green and stays that way until I turn the TV off and then back on. Ususally happens during channel surfing.
I had the exact same problem with my Toshiba 26" LCD; it ended out being my cable box. The cable guy switched it out for a better model, and poof! No more problem. P.S., you don't have to turn the unit off and on; simply press a menu or information button and it will come right back. Using the TV power button that often can be hard on your set.
1helpful
TEAC LCD191SD WIDE SCREEN LCD TV WHY NO SIGNAL
U have a signal word bound around or said no signal in ur LCD Screen?Than it ur colax cable not getting signal comming in.Try reset ur cable or satalite box by turning it off/on.IF the LCD screen totally black,try unplug,replug might get picture back.Not than must replaced the main video backlight board it dead must be replaced.
2answers
Green Screen
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
