Agitator not working
My whirlpool agitator does not work at all, I just hear the motor humming. What do you think is the problem. Thank You
  • 85 Answers
Advance timer to spin cylcle if it doesn't spin you have a broken motor coupling. its about a $10 part
Posted on Dec 16, 2008
Need to replace the drive belt (I think!) on a Whirlpool washer model# 110.20912 990. The agitator won't turn but I can hear the motor run. Please tell me how to replace the belt. Thank you!!!
According to the model number you provided, there is not a belt on your machine. Probably what has broken is the coupler between the motor and the transmission. http www searspartsdirect com Kenmore Washer Parts Model 11020912990 0582...
Look at part # 13 the coupler. Hope this helps!
Feb 17, 2015 | Whirlpool Washing Machines
I have an older top load whirlpool ultimate care II washer and during wash cycle it's as if the agitator is slipping and I can hear it as well. Help!! How can I fix it before it's too late!?
lift the agitator out and check the drive block-it probably shot-the humming is the motor running and not hooked up to the tub-cheers Denny p s keeping your old machine runninng is probably more desirable than buying something new that won't work as good
Oct 24, 2013 | Washing Machines
The agitator does not work
Possible that the drive belt has failed. You need to open the machine to look inside and see if the belt has come off. Also if the motor is not working check the power to the motor , if available and humming the capacitor is a suspect.
click on : Belt replacement
Jul 02, 2012 | Whirlpool Washing Machines
Whirlpool mach. is humming when u turn on but agitator won't move
Hello friend,
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
In case of the agitator not moving check the following:
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer.
Check the above, It seems that your washer needs a repair and would not be possible to do it yourself. So yau will have to call a technician.
Do feel free to get back to us in case of any other assistance if problem is not solved or if you have any other query.
Thanks
Mar 05, 2010 | Whirlpool Washing Machines
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not agitate or spin
it looks to me u need a new motor as the one u have is burned out...this is the humming u hear....contents insurance will pay for new motor if u have one
Apr 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator wont work, quiet hum and smell
Noises
Often something works it's way into the pump and makes a clicking or scraping noise. Another bad spot on this washer is the snubber ring that sits between the base and the drive unit.
1) Whirlpool, Inglis, (some) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1picture2.
(2) Whirlpool, Inglis, (some) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
Apr 03, 2009 | Kenmore Washing Machines
Won't spin
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken.
Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Last the huming may be the motor is sized! Done, finished!
This is not a do it your selfer job
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My Kenmore series 70 washer will wash and then the machine stop. If I move it to the rinse cycle it will start agitating again and then it will shut off again. It seems li9ke the spin cycle isn't working
Welcome
Either of these three problems may be occurring.
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Thank You Please remember to leave a rating.
Dec 12, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
