Question about LG DLG7188 Gas Dryer
I can't figure out how to get into my front loading LG dryer.
I need to do a natural gas to lp gas con version but can't get inside.
  • Anonymous Mar 04, 2009
    Does the controlpanel have to come off befor the front can be removed?
    How does the center control knob come off?
  • 113 Answers
Heres a link to the schematic. Youll have to start by taking the top off. There are 3 screws on the rear top that hold it on. After you take them off, you should be able to slide the top off by pushing it back. In the diagram youll see the screws in the top front that hold the front panel on. Also when you open the front door there are a couple screws that need to come off the face. From there the front panel should pull off. Hope that helps. Dave www.washermd.com
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f50030341-00002.png
Posted on Dec 16, 2008
I have a lg dryer DLG5988S is it natural gas or lp?
most of these dryers are factory set for natural gas and need to be converted to propane if using propane
Feb 09, 2011 | Dryers
How do i convert from natural gas to LP or Propane?
You need the LP gas conversion kit: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-lp-gas-con-item-number-ap4300853.aspx . Other sources may exist. This includes a replacement orifice and a spring and the installation instructions. The orifices are swapped with a small wrench. The spring fits inside the regulator inside the blocking plug.
You will also need to remove the cap from the regulator and turn it over. This makes the regulator compatible with LP gas. It's easy to tell which side is which - each side is labeled.
However, the conversion kit should be installed by a professional trained for the job. Your local LP dealer should be able to help you find a repair person with the skill. (Improper installation could result in a gas leak.)
I hope this helps.
Dec 09, 2010 | Amana NDG7800AW Gas Dryer
How do i get to the gas orifice to install conversion kit from natural gas to lp
You will need to call LG parts and ask for the part numbers. Their number is 800 243 0000
Good luck
Sep 25, 2010 | LG DLG5932W Gas Dryer
Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jan 08, 2009 | Frigidaire Dryers
Natural gas to propane conversion LG dryer
You posted under a combo washer / dryer WD-4343RHD.
For a gas dryer, conversion is to replace Nat gas orifice with LP one (the LP orifice has a air hole going cross ways through it) plus screwing the regulator blocker (brass slot head screw on top of the gas valve) all the way down (if you missed that step, I would expect your symptoms). Also, make sure you have a good vent with strong air flow at the outdoor outlet. If poor vent, short cycling may occur.
Nov 22, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Thermal fuse
hi. thanks for the question. the thermal fuse is located in the dryer, on the air duct, small piece with 2 wires to it. replace . also clean venting, and inside the dryer.thanks the appliance doc
Oct 05, 2008 | Dryers
Kenmore Frigidare Front load dryer 417.93042203
The front panel clips usually hold by friction. Just pull gently on the upper corners and it should hinge down.
Aug 08, 2008 | Kenmore 73952 Gas Dryer
Lg 7188 gas dryer conversion to lp
How do you get the front off a LG gas dryer
May 02, 2008 | LG DLE5977 Electric Dryer
Lg gas dryer lp conversion
On the regulator on the burner you remove cap and turn upside-down and reinstall.
Nov 18, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Open Questions:
LG DLG7188 Gas Dryer Logo
267 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
