Question about Whirlpool GGQ8831L Gas Dryer
The dryer worked then we moved it and replaced the cord. now it does not work. it will start but only runs if you hold the button down
  • Dan Webster
    Dan Webster May 11, 2010
    Why did you replace the cord?
  • 113 Answers
The Model # would help to answer this. Is it an evenheat dryer. Should say evenheat above the timer. If it is it will have a computer panel inside the control panel that may need replacing. You will usually see a burnt resistor on the board. If it is not an evenheat dryer, than youmost likely have a bad relay inside the control panel. There are 2 relays. One is the motor relay and one is the heat relay. The heat relay will be the problem. Part # 3405281. I believe its the relay on the right, but cant say for sure without a model #. To check, the easiest way is to order yourself a new relay, theyre cheap. Unplug the old relay and plug in the new one. If it works your set, if not try the other relay. Theyre both the same part, just for a different source. If you have anymore questions you can contact me through my forum at www.washermd.com, thanks
Posted on Dec 16, 2008
Dryer only runs when I hold down Start button works fine only if I hold the start button down This is a gas dryer
souds like the door switch is broken or malfunctioning . unplug the dryers power cord , locate switch by removing top cover no need to remove switch just yet. locate two wires coming from switch . and check function by means of a continuity tester or multi tester. touch the red test lead to one wire termial and the black test lead to the other , now set your meter to resistance reading . with switch normaly open ie; (door open) youll have high resistance reading and with dooor closed or switch held in youll have no resistance. or an audible tone on your tester. if no tone or high resitance reading occurs with door closed or switch held in the switch is bad. hope this was helpful.
Feb 11, 2013 | Dryers
My kenmore dryer will only run if i hold down on the start button. this has happened to me before but i cannot remember the steps to take inorder for it to reset.
first check the door safety switch,, if its bad the dryer won't run,, if that checks out ok, its time for a new switch for the start button, to check these, and do the door switch first, unplug the door safety switch and place a jumper wire between the 2 wires leading to the switch, try starting the machine making sure your away from any moving parts , if this works, replace the switch, if it stays the same, do this same procedure to the switch for the start button
Jun 21, 2011 | Kenmore Dryers
Amana Dryer will not work,will not stay on,makes funny noises
during the process of moving your dryer, it sounds like the drum became dislodged. With the dryer off, open the door and try to move the drum by hand, if it sounds like something is 'dragging' them the drum is off its bearings. IF it is, the quickest way to get help to take it apart is go online to youtub, type in your dryers name and model number and ask how to replace drum
Apr 27, 2017 | Maytag MDE2706 Electric Dryer
I have to hold the push to start button for the dryer to run
Ok you are really not that ignorant, all dryers shut off when you open the door and no holding down the button won't make it work.
Mar 20, 2009 | Kenmore 63942 Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Whirlpool Dryer (LER7646E) not working
check your power cord and the receptcal if you see any discloring on pronges of your power cord you'll need to replace cord and the receptical it could be shorting out
Dec 13, 2008 | Whirlpool LER7646E Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
Whirlpool GGQ8831L Gas Dryer Logo
90 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
