Propane heater. Had storm which tripped filter and heater circuit breaker. When restoring power heater won't fire and displays RVO
SOURCE: the raypac 2100 pool heater turn on but when you go to fire it al
If you hear it sparking, verify the spark is happening INSIDE the combustion area and not shorting out at the ignition module. Also verify you actually have gas available and the gas valve is turned on...
SOURCE: Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
SOURCE: My raypac 2100 was working
The EOL code means End Of Line. It means the heater has given up trying to run. There are a number of problems that could cause this issue. There could be no gas pressure, a defective gas valve, or something wrong with the control board, etc. To determine exactly what is wrong a person qualified to diagnose the problem will need to follow a diagnostics document from Paypak or call Paypak's technical support line. If you have a volt/ohm meter and have some debugging experience you might convince a tech support person to help you diagnose what the problem is. If you are not successful with that idea then you will need to find a pool equipment professional to do the job. I hope this helps.
RVO is not listed in manual. Anyone know what it means?
