Question about Microsoft Xbox 360 Console
Will not turn on
My XBox will not turn on. I have everything plugged in securly and have cleaned all the outlets and connectors. What do you think is wrong?
  • 3 Answers
I had the same problem with my xbox360 i tried everything, but if you have a warenty you can fix this problem rite away just call microsoft and provide them with the information that they need to help you out with a warenty it might take 2-4 weeks but look on the bright side you'll be able to play all you want =)
Posted on Dec 16, 2008
Power brick red light when plugged into the xbox 360 but when its not its orange
If the power brick is plugged into a surge protector then try to plug it directly into the wall outlet instead (note: xbox power brick has it's own surge protector)
Make sure that the brick is clean and the ventilation holes are not blocked.
Unplug ALL cables from Xbox 360 and plug back in securely. (note that though some cables might appear to be secure but they might not be seeded correctly. Verify.)
Check power source and make sure there is no fluctuating current preventing stable current to the Xbox 360 when attached? Try to plug the xbox into a set in another room and see if it corrects itself. If so then you know that possability of outlet issue is likely.
Lastly... your power brick might be bad.
Jul 19, 2011 | Video Game Consoles & Games
My kinect is not workin on the kinect its self only the red light is on and no green what is wrong and it is askin if my power supply is plugged in
Original Xbox 360 console
  1. Turn off the console.
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure the cable is working properly. If you still do not see a green light your cable needs to be replaced. Contact Xbox Support.
  5. Turn on the console.
Other solutions can be found on the Xbox support site by following the link below.
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-1.aspx
Mar 08, 2011 | Video Game Consoles & Games
The light is flashing orange on adapter and no power to system when turned on
It is possible that there is some foreign particles inside one of the connectors. Since the power supply does come apart and also disconnects from the unit, you can try to clean it to see if it will sort out your problem. Here's what to try:
1. Disconnect the AC adapter from the wall and the console. Let it rest for a few hours so that you do not electrocute yourself.
2. Disconnect the wall power cord from the AC adapter brick. Check the connections on both ends to see if it needs to be cleaned.
3. Clean any ends of the adapter with alcohol solution (isopropyl, or "rubbing" alcohol). Make sure the connection to the console is clean as well. Allow to dry.
4. Reconnect all necessary parts and try your console again.
If that does not work, there could be another problem with power flow to the AC adapter or a problem with the adapter itself.
Feb 28, 2011 | Microsoft Xbox 360 Console
I just purchased an xbox kinnects bundle. I was doing the set up and it asked if I wanted to update so I said yes. Then the xbox turned off and will not turn back on. Please help!
Yikes...I would check to see if the power plug did not come off the xbox, then check the outlet to see if it's working, I would then remove the xbox kinnects bundle, then turn the xbox to see if its working.Then start allover. Good Luck!!
Jan 22, 2011 | Microsoft Xbox 360 Console
Trying to install kinect to xbox 360 get error message C00000C2
Welcome to Fixya!
Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update
Solution 2: Check the cables Xbox 360 S console
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
  4. Turn on the console.
?Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 01, 2011 | Microsoft Xbox 360 Console
It green screens after 10 mins
Are you using hdmi cable. If so your hdtv needs to have it's hdmi port reset .First unplug everything even the TV and xbox. Then disconnect everything and unplug every thing from the wall outlets. Then plug the TV back in and hook everything back up. The HDTV even with the power off can have it's hdmi port bumped so you need to unplug it to reset the ports.
Thank you
May 09, 2010 | Microsoft Xbox 360 Console
Xbox 360 won't turn on
To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Sep 01, 2009 | Microsoft Xbox 360 Console
I have a Yellow Led light on power bar, xbox will not turn on
Here ya go! This should help you out, I have also had this happen to me. Don't worry, its nothing like the red circle of death.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Hope this helps you out! Don't forget to rate me :)
Apr 09, 2009 | Microsoft Xbox 360 Console
Cant connect online
The way that i found to connect was to use a router, and connect it through that. it sets everything up itself.
Feb 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
