Question about Sharp AQUOS LC-20D30U Television
While watching TV, black box with scrolling text appears
SHARP AQUOS, 20" LCD LC-20D30UHad this LCD TV about 2 years. Lately while watching, all of a sudden this black box with scrolling white text just appears in the middle of the screen obscuring the picture behind. Lines of seemingly non-sensical text down from top to bottom.
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
satavlad
  • 405 Answers
SOURCE: Sharp Aquos LC-3237U keeps turning off what could
Check if the power menegment is enabled. Go menu> power control ind see if NO OPERATION OFF is enabled.
Posted on Nov 06, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
I have a Sharp AQUOS LC-32D47UA 32", black box
Press the cc button on your remote control. You want cc to be off. Play around with the cc button to become comfortable. Press it over and over again. Observed that a different closed captioning option appears on your screen each time you press the cc button. Now press cc and when it says cc off do not press the button anymore.
Jan 23, 2011 | Sharp LC-32SB21U 32 in. LCD TV
Tv screen keep going black,
did you check the sleep mode on the tv?
Aug 05, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I cannot change the channels on my direct TV receiver when tv is
Have you tried a factory reset on the TV.Also try unplugging the tv wait about 20 seconds and then plug it back in.Last check the trouble shooting in the tv manual
Feb 08, 2018 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
HDTV
Shouldn't have to, but HD through the wall connector may be an issue if you are wanting that. I don't know for sure. Almost all tv's made in the last 1 year - 2 years have digital tuners built in
Jun 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp AQUOS LC-20D30U Television Logo
44 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
