Question about RCA HD56W66 56" HDTV
RCA HD56W66 Power Issue
I read from a post that you fix about 10 of these RCA HD56W66 projection tv's a week. I am having a problem with mine where it won't turn on. I plug it in, the green light comes on and I can hear the tv starting to turn on, and then after about 2 seconds it shuts back off and won't turn on again until I unplug it and plug it back in, and then it does the same thing. I am a former military electronics tech turned civilian geek (network/system admin) so with the proper manual/instruction I can fix about anything, I just have no manual or schematics for this. The nearest repair shop for me can't make it down to me until New Years Eve and that's just to do an initial diagnostic, not even to necessarily fix it. Is this something you have seen before and do you have any suggestions for me? Any help would be greatly appreciated.
Thanks,
Jeremiah
  • 1 more comment
  • Brad von Oven Mar 26, 2009
    My 53 inch RCA is giving me a high voltage static (think it's called an arc?) and I saw it flashing, then a little smoke. If I wait 2 minutes it will repeat this process. Any ideas?
  • nglfloyd May 23, 2009
    Repairman came, did a complete overhaul. Our initial problem was the curved picture with red blue and green lines and blurry. Once he worked on this, something happened to the module. I am very upset about this but apparently RCA is just not a good tv. We paid a pretty penny for this about 3 years ago so this is so upsetting. I am resolved to just upgrading although we really can't afford it because the module apparently will be $200-$400 dollars.
    Genius:
  • 1,030 Answers
You hear what? is this sound a high voltage static? The fact that you have flashing light means the main fuse is good and your processor is receving power. THe processor is detecting a shutdown situation that causing it to shut down for safety. high voltage situations are the primary causes. but it can be one of about 20 conditions. at the shop we have a computer that reads error codes much like a autombile. the primary things to check for are a shorted horizontal output transisitor. if you hear a high voltage static then it means you tubes are trying to fire but are drawing to much current.
Posted on Jan 01, 2009
Where is the bulb located on a hd56w66 tv
If you have a HD56W66 it is not a DLP set it is a rear projection Tv set . id does not have a bulb it has three picture tubes one in red blue and green
Oct 20, 2014 | RCA Televison & Video
Rca hd56w66 no power not even the green light power board looks good suggestions to find the problem?
Check the fuse. Its located on the right side looking in the rear of the TV its the small board where the power cord plugs into. The fuse is on that board.
Jan 01, 2010 | RCA HD56W66 56" HDTV
Rca model hd56w66 turned off and the power light will only come on for a few seconds tv will not completely turn on
3 capacitors on your deflection board it will be bottom board on left hand sise of TV cp 150 2200uf 16v use 25v if it is puffed up on top it is Bad other 2 are cp114 cp120 220uf 35v in same circuit. For capacitors Call Mats 1-800-628-1118
Dec 15, 2009 | RCA HD56W66 56" HDTV
RCA hd56w66
DO YOU STILL NEED HELP WITH YOUR TV IF SO ,I WILL TRY AND HELP! First ck capacitors cp150 cp114 cp120 2200uf 16v and 220uf 35v if 150 is puffed up on top replace all 3 capacitors also ck Ribbon connectors there is 2 of them thst conect deflection board to SSB board. resolder all pinns on FBT flyback transfomer.
May 28, 2009 | RCA HD56W66 56" HDTV
My RCA TV Mode # HD56W66 is green and red.....how do I get it adjusted.
get a QUALIFIED TECHNICIAN!!!!!! or BUY A NEW TV!!!! ********
Feb 01, 2009 | RCA HD56W66 56" HDTV
RCA HD56W58
RCA HD56W58 Rear Projection TV quit today. Resistor burnt up r14705. Power light goes on and high pitched noise but no picture or sound.
Nov 09, 2008 | RCA HD56W66 56" HDTV
Rca hd56w66
reset? i know of no reset button on this set what are you trying to reset... whats your complaint on your set. I repair about 10 of these a week at the shop. so let me know if i can talk you through it. leaveing the set unpluged for 30 minutes is standard reset
Sep 05, 2008 | RCA HD56W66 56" HDTV
RCA TV
ok is this s hd56w66 or hd56w58? if its a 56w58 then it is a atc321 chasis there has been some issues with the splitter and defecllection boards with that unit
Mar 23, 2008 | RCA HD56W66 56" HDTV
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
RCA HD56W66 56" HDTV Logo
251 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
