Question about Toshiba Satellite A105 Notebook
Toshibs sat. A105 won't let me boot to any cd it says operating system not found
    Problem Solver:
  • 32 Answers
You need to enter your bios (setup at boot) and make sure that the cd drive is at the top of the boot sequence before it can start from cd.
Posted on Dec 16, 2008
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard drive.dell-bios-uefi.jpg
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Oct 29, 2017 | Dell Inspiron 1200 Notebook
My Toshiba laptop A105-S4034 laptop wont boot up correctly
The j is the drive letter that your laptop is expecting the cd drive to be and of course it is not. Go into the bios and select it to boot from the cd drive instead of the hard drive and try again. if it boots correctly from the cd the when you get the option to install windows make sure you delete the partition that windows was on. In fact delete all the partitons asyou have the cd's providing you do not have a data drive with all your info on it.
Jul 29, 2017 | Toshiba Satellite A105-S4034 Notebook
I have a toshiba laptop that on the bottom of the laptop it shows it to be an A105-S4184, model PSAA8U-SK7034, to my knowledge there has been no hardware changes but i did reload an operating system when a...
You need to make a bootable CD, put theToshiba DMI utility on the bootable CD; Boot from that CD, then run DMI utility to set the machine to match the designation on your recovery disks. That'll do it.
Jan 29, 2011 | Toshiba Satellite A105 Notebook
I need to reset a Toshiba A105 to factory settings it will not hardly run as is very slow
If you mean reformat that is possible. Just make sure you back up your drivers. You should also have a Windows operating system CD.
YOu can also perform system restore which will restore your computer to an earlier date.
System restore options is found under accessories and then system tools.
Cheers,
KA
Jul 09, 2010 | Toshiba Satellite A105 Notebook
Will not boot says operating system not found
if it was working before that message, then probably the operating system is corrupted.
insert the windows cd when you boot your pc and when the message "Press any key to boot from dvd" appear press enter.
Follow the screens to repair Windows. the sytem files will be restored.
Jan 25, 2010 | Toshiba Satellite A105 Notebook
Loose power connector
look on the toshib website theyshould have a manual
Jan 06, 2010 | Toshiba Satellite A105 Notebook
Toshiba satellite A105,My wife dropped laptop now when you try to start I get error message operating system not found, try to boot to bios and get several quick beeps
Harddrive has probably crashed or the connection have become loose. Flip the laptop over and look for the Harddrive assembly. Usually has 1 screw holding it in place. If you feel comfortable enough - remove the screw and pull the HD out and slide it back into place. See if the connections are simply loose.. If that does not work you probably need to replace the HD.
Jun 17, 2009 | Toshiba Satellite A105 Notebook
My Toshiba satlelite A105 will not boot up , comes up on screen black says pxe-e61: media test failure, check cable pxe-mof: exiting intel boot agent operating system not found
Go into SETUP (F2, DEL, Cntl-S or somesuch at boot time - or hold F1 key down and force and error and then change your BOOT order to CDROM, HDD. It is Currently NETWORK, CDROM, HDD or the like.
PXE is Network directed bootup, and your LAN connection is waiting or the proper code or instruction or server. You need to turn that off, and BIOS SETUP is where to do it ;-)
Hope that helps
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Cd rom not working
Let’s determine if your CD-ROM drive or your Operating System Software ( ie...Windows XP) is the problem.
You will need a bootable CD, you can use your “Dell Resource” CD or any other bootable CD disk.
Power on the laptop and tap the F12 key to get to the “Boot Selection Menu”. Insert the DELL “Resource CD” into the CD-ROM drive. Select “Boot from CD/DVD drive” from the selection menu.
If the laptop boots from the CD drive then you Operating System Software is the problem.
If the laptop won’t boot from CD then your CD-ROM is defective and needs to be replaced.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell Inspiron 1501 Notebook
Toshiba Satellite A105 Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
