Question about Dayton (3E379) Heater
Line voltage Tstat installation Dayton D-F79 elctric shop heater
Wiring in a 240 line voltage T-stat for this heater is confusing. I was under the impression that you could wire in the stat from the breaker first, prior to the heater unit. (breaker>stat>heater). It would act like a "light switch", right?
Well, there is a separate (from the power terminal block) Control Terminal Board within the heater that had a tag on it that read, "Attention. Thermostat MUST be wired to the control terminal board. This unit will not operate if thermostat is wired to the power terminal block. See wiring diagram..."
Following the diagrams in the owner's manual for the heater, and the Honeywell T-498B 4-wire line voltage T-stat, I wired the thing in as best I could figure from the contradicting info in the diagrams. (Haven't hooked to breaker yet).
I'm no electrician, but I can do basic house wiring, and the way they show to wire the thermostat to the control terminal block doesn't make sense to me.
It shows the L2-T2 (red wire side) of the t-stat connecting to a "W2" designated terminal on the control terminal block. This terminal dead ends. There is no wire inside the heater going from this "W2" connection. Doesn't this leave the circuit open?
The notes next to the wiring diagram talk about removing "jumper W1 to W2 when 2-stage thermostat is used." I dont see any "jumper" wire at this location. Should there be one here to complete the circuit or am I mistaken? The "W1" terminal is pre-wired in the heater, to the "contactor" in the heater unit.
I wish i could attach the diagrams.
Does this make sense to anyone?
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
Posted on Jan 21, 2009
Hello im tryin to wire a dayton model 2yu68 unit heater 208v .30 amp bbreaker with 10 awg 3 wire and simple thermostat and still wont fire up
Are you using this heater for a residential application? 208V is typically only seen in a commercial/residential setting. It would be unusual for a home to be wired in what they call 3 phase which is how a 208 voltage is obtained.
Hope this helps. I would strongly advise that you consult with an electrician as 3 phase voltage is not for the average DIY'r.
Oct 10, 2010 | Dayton D-F79 Electric Space Heater- the...
With the t-stat on high and a garage temp of 20 degrees it doesn't stay on. It cycles. T-stat?
it depends what u have the tstat set on butat 20 degrees it should not turn off at all does it have a wall tstat if so take the cover off an u should have 2 wires a red and a white tie them together and see if it stays on if it does then its the thermostat if not then u have another problem but it sounds like its the thermostat
Feb 26, 2010 | Dayton G73 Utility Heater
Wiring schematic, where can I get one? thanks
What in particular are you needing help with?This is a 208-230 VAC 1 or 3 phase strip heating unit that requires and external line voltage t-stat to control the temperature.
They also include auto-reset thermal protection.
What else do you need to know?
Dec 11, 2009 | Dayton Electric Heater
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Where do i connect load wires to 240 volt baseboard heater
Do you have the installation instructions, they will tell you exactly where to attach your high voltage.
Oct 27, 2009 | Heating & Cooling
Wiring
Since it is a 30 amp heater you need to run #10 gauge wire and use a 2 pole 30 amp breaker, since it is 208/240 volts. I hope this helped you.
Jan 14, 2009 | Dayton G73 Utility Heater
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Dayton (3E379) Heater Logo
529 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
