Question about Smeg S20XMF.1 Stainless Steel Electric Single Oven
Smeg S20XMF single oven (older version with analogue clock)
I've just bought a Smeg S20XMF older version with analogue clock - I was told it would need a additional 13amp power supply. From the back there is only 1 supply which I'm presuming is for the mains cooker supply 30amp. CAn any assist, Thanks Ash
  • Ash Wade Mar 23, 2007
    Thanks for clearing that
  • Anonymous Mar 15, 2014
    model SC107SG-8
    President:
  • 1,462 Answers
Does not need an additional 13a supply
Posted on Mar 20, 2007
Thermostat broken?
If your oven has a dial that is used to set the temperature instead of a digital control then yes, the thermostat has gone bad and is not shutting the heat off at the appropriate time.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 17, 2012 | Smeg S20XMF.1 Stainless Steel Electric...
Hi i have inherited a Smeg range cooker when I
Unfortunately, I don't have a solution for you. That's because I have exactly the same problem. Did you ever discover how to fix this problem?
Jul 14, 2010 | Ovens
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Oct 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg F170P-5 Oven
Models with analogue/digital programmer feature a "DEMO" function which deactivates the heating elements while leaving the other functions unchanged. To activate it, simply press the bell (minute minder), - and + keys for 3/4 seconds. A confirmation beep will inform the user that the function is active. To deactivate it, simply repeat the same procedure. This worked for my Smeg SC399X-6.
Aug 17, 2008 | Ovens
Smeg Oven digital clocks
two wires drive the clock itself so trace which these are by looking at the track on the card. join the other two. there may be linking across as well.is it a single oven?
Jul 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven SE399X/5 - digital clock issue
I'm glad I'm not the only one with this issue. My husband had the grill on too high and melted the buttons, I thought they weren't going in because of that but we've got new buttons and they're working at one side of the clock and not the other. For the meantime, you can get a thin screwdriver, or something, and poke it through the holes where the buttons would go to substitue. That will get it working in the short term.
Mar 07, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Smeg S20XMF.1 Stainless Steel Electric Single Oven Logo
472 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
