Question about Verizon Communications enV2 Cellular Phone
My charger for my env2 will not fit in the hole thing and wont charge. I cant figure anything out and i need to charge my phone ASAP please Help!!!
  • 1 more comment
  • Anonymous Dec 16, 2008
    I have a simliar problem to yours. My charger fits into the hole but while its recharging i have to put pressure on the end of it in order for it to rechardge.
  • great_guy30 Dec 29, 2008
    Yes I have the same problem. I have been putting pressure on it for weeks just to keep a charge.
  • Anonymous Jan 20, 2009
    Omg same here
    and its pissing me off soo much!
    did you guys get new phones to fix it?!?
I think you should go to the Verizon store and tell them about your problem. But if you've only tried putting the charger in one way, try flipping the charger over and then putting it in or put the charger in a different spot on the phone. Search until you find the right one!
Posted on Feb 09, 2009
Cant get it to charge correctly how do i fix it ?
The charger not only has to fit identically but must have identical electrical characteristics.
Jun 21, 2017 | SanDisk Sansa Audio Players & Recorders
I have the Verizon EnV2, & it won't charge. Is it my battery?
sounds like you have a short between the chrager and the phone... look and see if anything is bent where the phone and charger meet....if not.. call verzon your phone my still be under warranty and if it is they have to send you a new one ....of its just the charger they will GIVE you a new charger too
hopes this helps
Dec 09, 2009 | Verizon Communications enV2 Cellular Phone
ENV2 Phone will not charge and its not my charger! help please!!!
Try another battery. Those batteries usually only last a couple of years.
Aug 14, 2009 | Verizon Communications enV2 Cellular Phone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Cannot charge LG EnV2 VX91000 phone
The issue is the charger port on the ENV2 breaks fairly easily.Thefirst step is to contact your carrier to see if it is coveredunderwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.You can get an external battery charger to charger the batteryseparatefrom phone. cost about 25 dollars. Check out the following linkforones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
Jun 30, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
Can't charge my enV2
Hope that helps
Mar 07, 2009 | Verizon Communications enV2 Cellular Phone
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
Dec 16, 2008 | Verizon Communications enV2 Cellular Phone
is it the right charger? if it is it may not be fitting good because the charger might not be good or the charging port on the phone take it to a verizon store.
Verizon Communications enV2 Cellular Phone Logo
395 people viewed this question
Top Verizon Communications Cell Phones Experts
ismael castillo
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
