Question about Daewoo Televison & Video
How to repair my daewoo television it has no power?
  • Daewoo Master
  • 5,807 Answers
How to Repair Daewoo Television
Problem: No Power
Possible Solution:
• Initial Things you Need:
Multimeter
How to Use a Multimeter: 3 Methods - wikiHow
• Visual and Hands On Check up of electronic components
What to look for:
• Possible open or gone electronic components
Start with the power supply.
If you need to check right away for voltages:
• Check for the B+ or supply rails
• Check for low voltage regulators
• Check for possible cold solder joints,
Bleed first the Main Power Supply Cap with 4.7K
5W resistor to discharge .
Additional tip:
Standard Televisions
• You may need to acquire a service manual intended for
the specific model of your TV if your having a hard time
identifying some possible unidentifiable components.
Level of difficulty:
• Hard for a newbie
• Easy for those who have the tools and knowledge.
Posted on Aug 03, 2012
SOURCE:
Television no power
Check the main power supply regulator section circuit for the fault
Aug 02, 2012 | Daewoo Televison & Video
NO PICTURE ONLY SOUND
just ask the daewoo service center to repair your tv
Jun 19, 2010 | Daewoo DSJ-4710CRA 47" Rear Projection...
Tv power on and sutdown after a series of bips the green light change to red and stay red
Tv power on and sutdown after a series of bips Problem with the Daewoo DSJ-6000LN 60 in. Rear Projection Television tv power on and sutdown after a series of bips the green light change to red and stay red
Jun 15, 2010 | Daewoo DSJ-6000LN 60" Rear Projection...
My Daewoo TV screen just went all Blank n Black suddenly while it was running all fine Then this was accompanied by a strange clicking sound and now whenever i turn it on,it just shows nothing(blank...
The set has developed a short either in the power supply or the horizontal/high voltage circuit. The power supply makes a weird noise when it gets overloaded. This can get complicated so have a repair shop check it out for you. Thanks
Nov 01, 2009 | Daewoo DTQ-13V1FC TV
DAEWOO TV
If youe tech inclined you can open the unit and see if the fuse is blown if you are uncomfertable on doing that then your going to need to take it into a repair shop.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | Daewoo DTQ-27S5FC 27" TV
Standby light comes on but TV won't when turned on
I am having the same problem. Have you had yours repaired yet?
Dec 01, 2008 | Daewoo DSJ-5510CRA 55" Rear Projection...
Internal fuse keeps blowing and unable to power up on a Daewoo DTE-2898GB TV Set.
Typically this is because the horizontal output transistor is shorted or there is a major problem with the power supply. If you have no experience with TV repair, I would bring this in for a repair estimate.
Dan
May 02, 2008 | Televison & Video
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Televison & Video Logo
13,965 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
