Question about Panasonic Lands Phones
I received a set of panasonic 5.8 GHzphones about a year ago as a gift. They worked fine up until today when both phones stopped ringing or allowing me to receive or make calls. When I dial a number, it continues to show on the lit display, but when i press talk, nothing happens. What's the probles?
    Top Expert:
  • Panasonic Master
  • 57,208 Answers
Do you hear a dial tone . if not the phone company needs to be notified of the outage . that is why many people have cell phones also
Posted on Jan 14, 2018
SOURCE: Keypad not working during phone call
If sounds like DTMF is turned off on your phone. If it is then it is not sending the correct tone over the air which is why nothing happens. Go into setting, then to initial setup and key down toward the bottom and you should see DTMF if it is off change it to short or long and that should correct you problem.
Posted on Nov 15, 2006
SOURCE: Nokia 6020 not ringing
Change your Cellphone!
Posted on Jul 26, 2007
SOURCE: LG CU500 cell phone Call Divert Set problem
  • The issue is caused by the phonejack/memory chip assembly, located in the upper right rear of the phone has become unseated/loose and is causing your issues. I had the same problem and after I took the phone apart and put the assembly back in position, I eliminated the problem.
  • If you are not mechanically inclined and/or have access to small tools and an open area to work in, do not attempt!!!! There are numerous small parts including the side buttons and keypad and the above mentioned assembly that are exposed when you seperate the two sections that make up the back of the phone. If you attempt the repair be extremely careful to note the position of parts before you take it apart and make sure they go back in correctly. It is a bit time consuming but doable.
  • If you feel you can't do it yourself I'm sure that there are some online options for repair or perhaps a local repair shop that would do the repair. Good Luck
Posted on Jan 05, 2008
  • 65 Answers
SOURCE: Cannot call out or answer a call
The only thing I can think of is you may be in the wrong dial mode. If you do not have touch tone service you will hear the tones but it will not connect. Try setting it to pulse and see if you can call out. Check you volume or see if the mute has been set. Have you tried a different phone? you might want to borrow a phone from a neighbor to see if it is a service problem or just your phone.
Posted on Feb 05, 2008
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Posted on Feb 12, 2008
It worked fine until today. Only rings once and then disconnects. what can I do
If it is a landline phone, it may be receiving interference from other electrical devices in your home. Try moving the phone to another wall jack, or if using a router , remove router and go straight to wall jack. If problem persists, call your service provider's customer service.
Dec 23, 2015 | Panasonic KX-TG1033S Cordless Phone
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
I received this as a gift and removed it from packaging but never used it until I got on a Train a couple of months later. I have been trying to get in touch with Panasonic with no luck.
I went to www.panasonic.com and the website stated under repairs but listed the following phone number;
Technical Support: 1-800-211-7262 (Mon-Fri, 9AM-9PM EST, Sat-Sun 10AM-7PM EST)
Maybe the website will work for you later today - i clicked on support and entered the model number you gave.
Hope this helps and please rate my solution!!
Nov 23, 2010 | Panasonic SL-SX330 CD Player
Fax machine won't answer and pickup. I have to manually pick up the receiver and press start. This just started a few days ago.
You probably have it in the fax/tel or TAD mode. Press the butoon on the top right side of the keyboard marked "mode" until the light above it is on "fax" only. This mode (fax/tel) is for phones/faxes hooked to an answering machine. The "fax" mode puts in into the direct answer mode as a fax machine.
May 22, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon 1023if not receiving faxes automatically
Is this fax line shared with the phone? I believe there is a distictive ring setting in the add'l functions area under communication settings then receive settings. you would need to select a ring pattern different so the fax can tell between which types of calls it is receiving.
It has worked for me in serveral other installs
Hope this helps
TankMurdock
Apr 09, 2009 | Canon imageRUNNER 1023iF Black and White...
The sound on my Nokia 6133 has stopped
sounds like a short or a setting peoblem.try to set it and if that doesnt work take it to where you bought it they will look at it for you for nothing.i encountered this before.my problem was a short.
Jul 09, 2008 | Nokia 6133 Cellular Phone
Won't stop ringing
Well, I doubt it's the phone but just to make sure, swap phones around and see if the problem stays at the extension or moves with the phone. I am not familiar with the timed reminder feature but that certainly does sound suspicious... Have you used this feature before? Does it make your phone ring? There may be something special you need to do to answer the timed reminder and make it go away. Possibly canceling the timed reminder was too late after it was set off.
Sep 14, 2007 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
32 people viewed this question
Top Panasonic Lands Phones Experts
Henk de Ruiter
Henk de Ruiter
Marvin
Marvin
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
