Question about Refrigerators
Fridge is not cooling, but the blower is working
The relay is clicking on and off but the compressor does not start most of the time, is the compressor probably bad, and is it worth it to fix, it is our spare fridge for overflow and beverages?
  • 750 Answers
Hello
Welcome to Fixya
My name is Huum,
The relay needs to be diagnosed to find out which relay is bad. then replaced and if there are no other
underlying problems, this should do the trick!
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
Posted on Dec 16, 2008
Fridge makes a clicking noise everything in freezer melted and fridge won't cool. Model number ED5VHEXVQ03. I replaced the starting relay but not the resistor. Problem is the same still clicks...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Refrigerators
I have a Kenmore fridge model 53542300 the fridge and freezer are not cooling I can not hear compressor running nor is it hot. I do see the fans running for Fridge and freezer. I went to check the start...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 28, 2010 | Kenmore Refrigerators
Hi. I have an Amana/Maytag Fridge. Model ABD2233DES bottom freezer. The fridge was working fine, then it seemed like the compressor or motor started to make a funny noise. Like it was working hard or...
Refrigerator
heatman101
Dec 24, 2010 | Microwave Ovens
Here we go, I have a GE side by side about 6 years old... Started with the icemaker not dispensing ice consistently... then the ice stopped all together (even though the bin was full and not froze solid)....
The clicking you are hearing is the relay unit. Now it is for sure that the compressor is not working as the relay keep s tripping off.
So first of all to clear this doubt, let us checck the relay unit which is clicking. remove and check. most of the time the relays need to be replaced as a poor contact will not deliver good voltage to the compressor and it will shut off. So check this out.
One the compressor works and you notice there is cooling the sytem seems ok except that you must check if the thermostat, the auto defrost cut off timer works.
If after the compressor works the cooling is not good then you can decide on a replacement than to spend for expensive repairs
Sep 12, 2010 | Microwave Ovens
Compressor not coming on,temp is warm in freezer/fridge
You have a defective start relay on the compressor. That is your clicking sound. The overload relay is disengaging when you hear the click.
Replace the compressor start relay.
Jul 07, 2009 | Frigidaire Refrigerators
Refrigerator not cooling
the clicking sound you can hear is the relay or clixon as sometimes it is known by trying to start the compressor it may be stuck,first turn off the power to the refridgerator then turn the fridge so that you can see the motor,on the side of the motor you will see a small plastic cover remove it to expose the relaly remove it by pulling it towards you exposing 3 pins in a triangle shape give it a shake to free the solenoid inside the relay relace in the same way you took it off power up the fridge listen to see if you can hear the motor run constanly if it just starts and then goes of its more than likely the compressor is us
May 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Compact refrig not cooling
Hi!
It is due to multiple reasons, compressor and relay of the compressor being the most common. Is the fan working?
Feb 14, 2009 | Magic Chef MCBR440 Compact Refrigerator
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
First of all Give me model# and Serial#.
you will most likely have to replace main control board and evaporator fan motor. They have had a service bulletin out on this problem.
Jan 17, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
