Teac PD-H503 3-Disc CD Changer Logo
colin powell Posted on Mar 20, 2007
CD PLAYER Hi all, All functions on my cd player work except the digital display,nothing shows up.Whats the problem? and is it a big one?
Ashutosh Khandelwal
Level 1:
New Friend:
  • Contributor 50 Answers
  • Posted on Mar 24, 2007
Ashutosh Khandelwal
Contributor
Level 1:
New Friend:
Answers
50
Questions
0
Helped
15887
Points
69
IT MAY BE- IF YOU CAN OPEN IT THEN SEE WEATHER THE COMNNECTION CABELS TO DISPLAY ARE PROPER.IF THEY ARE THEN THE PROBLEM LIES WITH THE POWER SUPPLY TO DISPLAY.
What cause the display to go out on the kenwood kdc-235 cd player
You could try reading my tip on repairing Kenwood faceplates.
How to repair Kenwood Faceplate
Cheers,
Hi, I have an early model of a Wurlitzer 1015 OMT CD that keeps blowing two of the fuses on the amplifier when I turn the jukebox on. I have changed the fuses, disconnected everything from the amp (except...
we had the same problem with our 1015 vinyl omt, we replaced the ac/dc rectifier and the 2 big capacitors and the problem was solved. (it cost about 15 euro's) good luck!
1993 Toyota Vienta Ultima, ''Fujitsu Ten'' INF4 fault
i had the same proble. i happened to remove the changer from the boot for a few days and have a look inside but did not see anything wrong and when i put it back in it worked.
i expect it is as simple as disconnecting the changer from the head unit, turn the head unit on and off and then reconnect the changer resets the connection between the two.
3helpful
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Thankyou
Santa Fe 2005, CD player stopped working , need to reset
Also have the same problem, never had to get my car jumped though. When i switch to cd it is stuck on "CD2", also most of the time the screen does not show up and i am not able to use any of the buttons except the analog turn knob and power/volume.
Alpine cda7998 disc error
Try cleaning the lens first, if you can take the top off and are able to see the lens, using a cotton swab soaked in 91% alcohol wet the lens, don't rub it, then blow it off with computer duster. Or try a cd based lens cleaner (Radio Shack).
Good Luck Leadispenser
Cd function not working
you can always try cleaning the lense and if that dosent work exchange it for a new one
Sony system shows "initialising"
probably your laser is weak,if you're not qualified to open pls, visit nearest sony service center to have the laser replaced.
CD player not working
Insert Lens cleaning Disk, after cleaning the disk If the CD is reading change the lens.
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
