Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi with monlink new DVD player HDMI How to make work
Is there a way to make this work I want tho use my HDMI hook up on my tv but it only has the monlink on the back is there a cable ?
  • 179 Answers
The monolink is the hdmi on the mitsubishi. it acceps up to 1080i
Posted on Dec 18, 2008
My mitsubishi tv has a phone jack looking plug then a anntena plug part , how do i hook up a dvd player to it
it could be an HDMI port for connecting HDMI cable. If your DVD player has HDMI output then you can connect it.
or it could be a usb port for playing videos from usb devices like pen drives and portable hard disks
i dont think tv has a phone jack
Feb 28, 2016 | Mitsubishi Televison & Video
2005 mitsubishi tv
I'm assuming that your new blu-ray player only has an HDMI port and your TV does not. In that case, does your tv have a component cable output? This should be five plug-in ports (red, white, red, green, blue). Amazon sells an HDMI to component adapter that you can buy here: http://www.amazon.com/eForCity-538581-HDMI-Cable-5-Feet/dp/B005QWH4QA/ref=sr_1_1?ie=UTF8&qid=1382102257&sr=8-1&keywords=hdmi+to+component+cable
Oct 17, 2013 | Samsung Televison & Video
MITSUBISHI WD62525 - bad fuzzy picture with lines and waves - have MonLink hooked up to DTV. Picture does not improve even when playing a DVD. Used same MonLINK with another tv and picture was great !
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Apr 26, 2010 | Mitsubishi WD-52528 52" Television
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Connection of HDMI and Directv box
Monlink is the Connection I used with my Directv. All you need to use is the HDMI cords. Are you trying to also connect to stereo system or something other than a straight HDMI connection from Directv Box to WD-62525
Feb 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubisui green blinking light puch reset button it reset.
the blinking green light of death is a common problem
there are several solutions depending on you technical abilities
have a look here
www.tv-techs.com
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Ps3 hdmi to dvi on mitsubishi wd52327
What brand DVI connector and how many pins are on the connector. try a different cable
Dec 25, 2007 | Mitsubishi WD-52327 52" Rear Projection...
DVD UPSCAILER 1080i
get a new set of cable and try again if nothing then you will have to get a tech to check your set good luck.
Jun 04, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Dec 25, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
673 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
