Question about Ryobi Laminate Trimmer Kit
Collet chuck for Ryobi router R150 was broken
Seems to be bigger than 1/4" but not 1/2"
  • Anonymous Jan 08, 2009
    I have a Ryobi router r-150 with a broken collet and can't find a replacement part.
Ryobi - Sydney phoned and they had the part available so proceeded, thanks
Allan Japp
Posted on Dec 17, 2008
I have a Ryobi R-151 router with an 8mm collet, I cannot find and router bits with 8mm shanks, is their a 6mm collet, or adaptor available for this model? Regards Pete
There are 8mm to 6mm adapter sleeves available. If you take the collet along to a power tool store they may be able to supply you with a suitable 6mm collet. I can't find what type of collet is in the router, but I'm betting it is a ER-11 type in that size range.
https://www.maritool.com/images/ER11-Collet-1.jpg
Nov 23, 2016 | Ryobi Tools & Hardware - Others
I need a manual for Ryobi HT20VSK
The multi tool has no "chuck", it uses collets to fix the bits to the tool. Once the knurled cap is loosened or removed, the collet and bit can be removed. If the cap has been overtightened or left in the tool for an extended time, you can remove it by gripping the shank with pliers or vise grip and turn it to release the collet and bit.
Dec 29, 2011 | Ryobi Drills
Hi i have a ryobi r / 150 router which i,ve broken the collet chuck and bit adapter where can i buy them from,i live in victoria. kind regards dave.
Check here -> http://www.ryobitools.com/support/parts_batteries#
They handle just about everything, don't let battery tag deter you.
Mar 03, 2011 | Ryobi ROUTER KIT P163K
How do you remove the chuck assembly to replace? Just pull it off with pliers?
Some times the collet will get jammed in the chuck and you can lightly tap it to free it. If you use pliers be careful not to ruin your collet.
Jan 29, 2011 | Skil 1810 Router
How easy is it to purchase a collet 1/4" wrench for the Ryobi R163K router 8.5 amp
Ryobi part number 671250001 . This is the wrench the tool came with.
You can order from Ryobi 1-877-545-4099 or go to their website, find the closest service center, and order it through them.
Nov 22, 2010 | Ryobi Tools & Hardware - Others
I have a brand new Ryobi router model ERT241200. Am I supposed to insert the 1/4'' collet into the cavity where the collet nut is, then insert the bit into the collet and tighten the collet nut? I thought...
Do you have the collet upside down? It should fit in nicely and the lock nut fit over the top, no problem, If it doesn't, something is wrong. They only make 2 sizes of collets for router bits, 1/4 and 1/2 , if they get their parts from somebody who makes just collets, you could have easily gotten a different size in there. See if a router bit will fit the hole, then go to the store where you bought the router and ask them to try it in your router and see if it fits, they might have collets on the shelf. Check it out.
Jun 03, 2010 | Ryobi Tools & Hardware - Others
Router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
Apr 20, 2010 | Freud FT2000E 3 Router
I need a 6 mm Collet Chuck for Bosch 1617
Unfortunatly it doesn't look like Bosch makes the 6mm collets. I checked all my catalogs and came up with nothing
Jan 12, 2010 | Bosch 1/2" Collet Chuck For 1613 ,1617 ,...
Ryobi Laminate Trimmer Kit Logo
777 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
