Question about Polaroid IDF-1030 (826219006783) Digital Picture Frame
I can't make my memory card work with my idf-1030 digital photo frame
  • jinkajinka04 Jan 20, 2009
    My SD card used to work, when I added more pictures it stopped. I read other say the frame cannot handle over 2 G, but its only a 1G card, so I dont understand. It just freezes trying to start the pictures from the card.
    Genius:
  • 1,199 Answers
Even though the card may fit the frame it still may not be compatable (if you are useing an SD card try a sandisk DS card they are very compatible with these frames
I hope i was of help!
Posted on Dec 16, 2008
2 Suggested Answers
SOURCE: Nextar N7-202 digital photo frame
I had the same problem and called Nextar Support. The gal I spoke with asked how big my SD card was and informed me that the capacity for this frame is only 2 GB. Sure enough, my card was 4 GB. I transferred the pictures to a 2 GB card and it works great! (Note to Nextar: might be nice if they put this somewhere in the paperwork BEFORE people buy an SD card.)
Posted on Dec 24, 2008
Digital photo frame will not turn on
power supply unit fault. Visit repair store for checking the power supply unit.
Oct 06, 2012 | Polaroid IDF-1030 (826219006783) Digital...
Tip
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Digital frame won't read memory cards
Did you format the card before trying to use it?
Dec 30, 2009 | Polaroid T831 Digital Camera
Removing certain picutes from the frame
Hi, if this is a Pandigital frame, go to the manual pg.9 and follow instx under"Delete Photos from Internal Memory.
If it is another brand,try: on the Home screen menu,select Manage Photos( Make sure you do not have a Flash memory,camera card,usb etc connected to the frame!) and, under the Delete select the individual
photos to be deleted.
Hope this helps, but,I'm only familiar with the Pandigital
Dec 21, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Hello, My parents purchased me a digital Poloroid photoframe and i have downloaded my photos onto it but it keeps sticking and wont move on to the next picture. Also there is about 6 photos which are...
My first thought would be to format the entire memory. Then put the pictures on a couple at a time and see how they work.. It's possible that the coding on a couple of the pictures is corrupt and that would cause the type of symptoms you describe..
Beyond that I'd return it to the shop as it should be straightforward to set up and use..
Hope this helps.. :-)
Oct 06, 2009 | Polaroid IDF-1030 (826219006783) Digital...
How do you add music?
just copy music on your sd card and the picture frame detects it
How to delete a picture from a digital photo frame
Using the USB cable you can connect to your computer and change the photos or delete the ones you no longer want.
Plug the USB into your computer - If you don't see the pop up message letting you do this, Go to my computer and check the photo frame appears as a new device.
May 11, 2009 | Polaroid IDF-1030 (826219006783) Digital...
User manual
Download user manual of IDF1030 click Polaroid Support.
Dec 30, 2008 | Polaroid IDF-1030 (826219006783) Digital...
Polaroid Digital Frame Model XSA-01140B freezes up
I was using an 8G flash drive and had over 6G saved to it. I decided that maybe the frame could not handle that many G's so I deleted everything but 2G and it WORKS!!!!! Maybe anything over 2G is too much for it to handle. Try it and let me know. I am interested if this solves everyones problems.
Dec 19, 2008 | Polaroid IDF-1030 (826219006783) Digital...
I can't figure out how to delete individual pictures from display
The photo frame's interface doesn't provide any file management, so you can't delete, copy, move, or rename files on the display itself. Why can't you delete files on the card using your computer?
As for the problem with cutoff heads, etc.. Spend some time on your computer to make all your images in 640 x 480 pixels in size and save them all in .jpg format. This should solve your problem and makes the display work quickly.
Nov 23, 2008 | Polaroid IDF-1030 (826219006783) Digital...
Polaroid IDF-1030 (826219006783) Digital Picture Frame Logo
200 people viewed this question
Top Polaroid Photography Experts
Myrddin R Emrys
Myrddin R Emrys
NOEL
NOEL
David Payne
David Payne
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
