Question about Panasonic NV-GS11B Mini DV Digital Camcorder
Black bands and skipping in playback
I've had this problem for a while but it has now become really annoying. Although recording does not produce any errors, trying to play pretty much any tape produces three wide horizontal black bands across the screen and playback is jittery, skipping and with no sound. You can also hear small clicking noises, like if the tape is not engaging properly. I suspect it's a playback rather than a recording problem as it happens intermittently (though more often than not lately). Cleaning the head repeatedly has not helped. I also had it checked professionally but they could not reproduce the problem (with their own tapes). Could it be a tape rather than a camcorder issue? I use TDK tapes. Thanks, much appreciated.
  • 3 more comments
  • sebbe Dec 19, 2007
    I have the exact same problem with my camera. I guess that is has something to do with the mechanism inside the camera as the problem came along wirg "push reset button" issue.
  • Virginijus Feb 18, 2008
    Yes, and I have the exact same problem with my camera.
  • mcnaught May 16, 2008
    I've got this problem too, and I've tried the head cleaner, and it doesn't make an ounce of difference.
  • PEV1 Jun 15, 2008
    Yes I have identical problem!
    Only used the camera very seldon from new (about 4 years old now so no chance of help from Panasonic guarantee!)
    Dis someone say they solved problem by cleaning head with alcohol?
    Please confirm if this is the case
    Thanks
    Ray
  • winklewhitty Jul 04, 2008
    Same problem here too. bought the recorder back in 04, it's been fine until about 2 months ago when it intermittently started playing back with black lines on screen and no sound. If I ejected the tape and put it back in, sometimes it would return to normal, but not all the time. I haven't used it for a few weeks now, and I just turned it on, and this time instead of the black lines, it sometimes gave the "reset button" message, or if I took tape out and put it back it, playback didn't work at all - just had a black screen and gave a ticking noise in the mechanics, like something wasn't working properly inside. I just tried to take the tape out and put it back in (again!) and low n' behold! - it's working ok now.... (sheesh!) Just notcied on the panasonic website that they've recalled camcorders from 03 and 04 (similar model, but not this one) because of an error when it's in camera mode. Hmmmm?? http://panasonic.com.au/support/notice.c...
    Problem Solver:
  • 10 Answers
Thank You Guest, this this solution is helpful, I clean the head with alcohol and the problem is solved.
And thanks for FixYa for the technical support.
Posted on Mar 06, 2008
Recording Playback
Does it just skip. When you try playing it on your computer or on the camara itself after you upload it to your computer?
May 11, 2012 | JVC Everio GZ-MG30 Camcorder
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
No sound on movie playback
This camera does record sounds. But, it doesnt look like it has a speaker in it to play them. So, yes unfortunately you wont be able to hear what you record unless you are using something else to playback what you have recorded.
Good Luck.
Apr 09, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
Skipping during the recording process
"trying to record during playback"?... You can't record while playbacking in stereo mode, only in multitrack mode.
Mar 08, 2008 | Zoom H4 Handy Recorder
Camcorder wont playback
SOUNDS LIKE YOUR CASSTEE COMPARTMENT IS BAD.. TRY CLEANER CASSTEE.. MAYBE THIS WILL PROLONG THE AFFECT. LET ME NO IF THIS HELPS
Feb 28, 2008 | Video Cameras
Canon SD 700 IS Movie Sound Issue
This is because of low light and low frame rates in the camera. It records the sound on time but the picture delays. In the camera's video menu, choose a higher frame rate to help this a little. Honestly though, If you want to shoot better video get a video camera.
Sep 14, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
No colour at playback when tbe switch is on
The DNR boards for these machines can go bad and produce a black and white picture. Try swapping the DNR board.
Apr 30, 2007 | JVC BR-S822DXU VHS/S-VHS playback VCR
No chroma on playback
Bad heads may produce a loss of color in playback. If you have a spare head, swap it out and confirm this.
Nov 15, 2006 | JVC BR-S822DXU VHS/S-VHS playback VCR
Panasonic NV-GS11B Mini DV Digital Camcorder Logo
225 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
