Question about Pride New Mobility Legend 4 Wheel Scooter
Pride victory Scooter battery charged won't run
My wife fully charged the battery of her scooter at work and when she puts the key in says that it is fully charged and when she presses the lever to make it go it makes a clicking sound but will not move. This sounds similar to other scooter problems but not the clicking sound. Do you have an answer? Anything would be greatly appreciated since there is no scooter repair person in our area that we know of. Thanks.
  • 1 more comment
  • Anonymous Mar 14, 2014
    battery fully charged, makes a beeping sound when turned on but wont move
  • Anonymous Mar 16, 2014
    battery test full charge,when switch turn on the lites go to green then to red on handle bar,with a click in the brush motor control
  • Anonymous Mar 17, 2014
    On reversing my scooter i have noticed that it has started squeaking, noise sounds as if it is coming from the axel rather than the wheels themselves. Also on going in forward motion we all know of the ticking sound well mine seems to have got louder over the past few months, would it be advisable to open the axel and look at the brushes or to see if it needs greasing? any advice would be appreciated please.
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
    Problem Solver:
  • 32 Answers
The clicking sound is most likely the motor relay engaging and disengaging. Most scooters and wheelchairs do this when in neutral, or when damaged.
I would first make sure its not in neutral by switching a petal, or lever in the back or at the side of the scooter. (you may need to do this on both sides) You should switch this when the scooter is off because you will need to restart it afterward anyway.
If that doesn't work you most likely have a motor issue if the battery is charged as you describe.
Posted on Dec 16, 2008
Victory pride 2002 won't work?
hi Wendy it sounds like the batteries are so low that they can't even power the horn ?
check the batteries connection and the reset fuse situated at the rear .
regards
Rob
www.gewizrepairs.co.uk
Feb 18, 2017 | Pride Health & Beauty
My gogo ultra is showing fully charged and horn beeps, when i put key in it beeps fast 10 times and 5 beeps after
5 beeps usually means scooter is out of gear, but since the lever is in the drive position and the scooter gearbox/differential is engaged, it seems that the controller is not sensing the gear change. Possibly a faulty micro switch in the motor housing can be the cause of this, usually the micro switch is pressed down by the drive lever and if the switch is pressed down the motor controller knows the scooter is in gear.
Feb 11, 2015 | Pride Mobility Products GoGo Ultra X...
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Jan 19, 2015 | Pride Health & Beauty
I have a victory pride mobility scooter the battery is fully charged and it won't run I tried to reset but nothing worked
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
May 21, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Altea 4 mobility scooter battery problem
hi, the battery's sound okay, have you made sure the scooter not in free wheel mode ? check the lever attached to the side of the brake ,,,
Check the wiring going to the axle .. At worse the controller has called it a day...at best a loose connection,,, controllers are repairable..
Regards
Rob
Apr 20, 2014 | Pride Mobility Products Health & Beauty
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
Pride New Mobility Legend 4 Wheel Scooter Logo
963 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
