There is an energy save setting on your controls. Turn that off if you don't want tv to keep turning off while you are changing inputs. Hope this helps.
IF your Fans are running then your ballast board is not working replace it. A Bad Lamp Fan can also keep set from turning on otherwise your lamp needs replacement
Please check the sequence in which your warning light flashes.
I will tell you what might be the problem according to the fashing of warning light,
If,
Flashing repeatedly --- Improper voltage supply
Flashing once --- Malfunctioning of fan
Flashing twice ---excessive temperature
Flashing 3 time or more--other problem
When flashing occurs please remove the power cord from receptacle and inform your dealer about the flashing sequence.
